i hate my bose cd player
Old Mar 21, 2006 | 11:23 AM
96maxinSC's Avatar
maybe this belongs in audio, i dont know, i guess i just want some quick help
i have a 96 maxima with the stock bose stereo system and the cd player gives me all kinds of problems, especially when its hot out. even little bumps in the road make it skip, and sometimes when it skips it will stop playing for 10-20 seconds, then start again on a completely different track. sometimes when it plays you can hear a static sound in the background, and other times it doesnt play at all.
i want to just replace the head unit but i read in the faqs that you can't use the stock speakers with an aftermarket head unit, and i simply can't afford to change out the speakers and everything right now (college kid = broke).
so what should i do? should i replace it with a different stock bose head unit or am i likely to have the same problems?
thanks for any help
Old Mar 21, 2006 | 12:01 PM
nismos14's Avatar
§è~® f®ÈÄk
Read the AUDIO faq's that will show you how to do it.
Best solution though, is to remove all the speakers and get a new cd player.
Old Mar 21, 2006 | 12:20 PM
tcaughey's Avatar
You can get an aftermarket CD player and hook it up to the stock speakers. It's actually easier than you'd think. It doesn't sound THAT bad either. My system was hooked up that way for a while, untill I replaced all the speakers. All you need is the adapter that is talked about in the audio forums. Go there and ask around.
Old Mar 21, 2006 | 12:21 PM
tcaughey's Avatar
o yeah, like you said, you can go out and get a different stock Bose system that will fit the year of your maxima
Old Mar 21, 2006 | 12:39 PM
96maxinSC's Avatar
yeah i may just get another stock one but I don't want to end up with the same problems
Old Mar 21, 2006 | 01:06 PM
SiClone's Avatar
Doesn't like Crutchfield provide you with all necessary installation hardware or adapters if you buy a deck from them???
Old Mar 21, 2006 | 01:37 PM
eelcram's Avatar
I replaced my Bose with a Pioneer
It was very easy to do. Just used the regular radio harness and a antenna adapter and it's been working great for more than a year.
Mar.
Old Mar 21, 2006 | 01:42 PM
Crushed's Avatar
replaced with Pioneer also
I think around 80% of all 4th gen owners stock bose headunit blew out on em eventually..hopefully u can find a good one
Old Mar 21, 2006 | 02:12 PM
Tim96I30t's Avatar
Get a 99 Bose, all digital no stupid ***** to adjust. Just got a 99 Bose for $45 plus $15 shipping, much better than the 96 Bose. Looks 10 times better and I never have skipping problems with mine and I live in the NE. My 96 would skip sometimes, they must have changed something over the years it is much better.
Old Mar 21, 2006 | 02:25 PM
bobjohnson's Avatar
Blazin......
Im on my replacement too. I got a 96 tho..
some audio guru posted this a while back saying the older 95-96 Bose play burned cd's better but the 98-99's tend to play fine for awhile then they crap out... thats just what ive always heard....
I replaced my Bose w/an aftermarket and the sound is COMPLETELY different.
It definatley did NOT sound like bose speakers without the Bose Headunit.
and yes, i use all those worthless 50$ converters and junk.... sounded trashy
Old Mar 22, 2006 | 08:32 AM
Tim96I30t's Avatar
I have heard alot more problems with using the bose speakers with an aftermarket headunit even with the right adapter. I wouldn't change the headunit without changing the speakers. When you add an aftermarket headunit it cuts out the amp and just plays 2 ohms through the speakers that are made for 1 ohm. You can also put an 05 in dash 6 disk Bose with small mods to the bracket and it plugs right in. Any Bose will work just measure the L and W, the plugs are the same just some are different shape.
Old Mar 22, 2006 | 08:51 AM
russianguy's Avatar
does anyone have a functional unit in good condition
Old Mar 22, 2006 | 10:16 AM
max95q's Avatar
Pathfinders Bose headunits also fit the DIN unit for maximas. Im looking around for a 2002. The 2005's are nice but they dont have the tape deck. Best part is that they have the in-dash 6 disc changers and RDS. Its plug and play from what Ive heard and seen.
Old Mar 22, 2006 | 10:28 AM
psu2fan's Avatar
thanks for any help
I had the same problems you did. Ended up replacing my 96 headunit with a pioneer unit. THough I could get the unit elsewhere for cheaper I got that along with all the necessary add-ons for a good price from crutchfield. The most important thing to get with an aftermarket receiver is a gain adapter. Before I adjusted the output with the gain adapter, my pioneer didn't sound very good. Once I did the adjustments however, the sound was easily as good or slightly better than on my stock bose headunit. Use crutchfield to find out what you need, then shop around for the best price. I was lucky enough to find a $30 off coupon to use with my crutchfield order, use google it's your friend. And get a GAIN ADAPTER please!
Old Mar 22, 2006 | 11:25 AM
Ralow's Avatar
I have a 97 Bose OEM Head Unit if you want to buy it. I was just about to put it on eBay. I replaced it with a 2001 G20 head unit so I could hook up an auxillary for my XM radio (the auxillary adapter wouldn't fit a 97). It works fine but it does have a little static on some burned CDs. It will play CDs burned on the slowest speed...all my CDs are burned on the fastest speed and I didn't want to re-burn all my CDs. Otherwise its good as new...it plays regular CDs with zero problems...radio and tape work fine too. I'll let it go for $50 plus shipping. Its just plug and play if you want to keep your BOSE speakers. I'll even send you a print out of how to install it. PM me if you are interested.
Old Mar 25, 2006 | 06:02 PM
99maxeclipsemtx's Avatar
buy a wiring harness and get a new cd player factory cd players are junk on all cars maximas dont need a dash kit except for a pocket under the deck which isnt necessary. also get new speakers unless oyur on a tight budget when i worked at a stereo shop and we worked on infinitis lexusa nd high end foreign car and we put an aftermarket radio in it sounded like crap. so wed run speaker wires from the new radio to the speakers to bypass the amp and it would be louder even with the factory speakers
Old Mar 25, 2006 | 06:55 PM
blacck_dragon's Avatar
i had similar problem i just burned my CD at slower speeds like 16 x instead of 48x in terms of audio it suppose to be better.
Old Mar 25, 2006 | 07:21 PM
Zeppelin340's Avatar
What are these adaptors everyone is talking about. Why are they needed? Cause i just put in a JVC stereo, and i'm not getting any sound out my speakers at all. It's ****ed.
TKHanson
Nov 24, 2018 01:39 AM
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
