Clutch fluid disappears
Old Mar 25, 2006 | 04:10 PM
alleydawg6's Avatar
Livin dreams thru his Maxima
for the past week my clutch fluid has been mysteriously dissapearing on me ... every 3 days it falls in between the max line and min line and I fill it back up to the max line .... the clutch feels fine when I press it, which means it is building pressure. So I don't know if it is leaking from the clutch fluid line or it's just being taken in by the engine ... I'm new to the forum so I don't know the proper terms ....
Old Mar 25, 2006 | 04:11 PM
s0ber's Avatar
check around the slave cylinder for any moist spots
Old Mar 25, 2006 | 04:26 PM
alleydawg6's Avatar
would that mean the slave cylinder is leaking?
Old Mar 25, 2006 | 05:24 PM
njmaxseltd's Avatar
Difibulation modulation is the cause of fluid that dissapears mysteriously.
You've got three things to check.
1) Slave cylinder
2) The lines to the slave cylinder
3) The clutch master cylinder
My educated guess goes to a leaky, worn out slave cylinder.
Old Mar 25, 2006 | 05:28 PM
BlackMaxdout's Avatar
the hydraulic lines are known to crack and leak after a while. Check those too. They run over the top side of the tranny.
Old Mar 26, 2006 | 06:32 PM
alleydawg6's Avatar
thanx alot guys ... I'm gonna check on those things tomorrow after work ... I'll keep you guys posted
Old Mar 26, 2006 | 08:10 PM
Apparition's Avatar
Ichiban King
Yea I looked at the top of my tranny and its kinda wet looking with some sort of oily residue and btw same deal with the clutch fluid disappearing a tiny bit, little by little.. is that normal or am I to suspect the same thing?
Old Mar 26, 2006 | 08:41 PM
zazon's Avatar
clutch fluid disappearing is not normal, man
Old Mar 26, 2006 | 08:59 PM
Apparition's Avatar
Ichiban King
No I know that but its taken like 4 months for it to drop the smallest amount so..
Old Mar 26, 2006 | 09:03 PM
zazon's Avatar
ya but i mean for the price of 50 bucks at napa you can get a new one and save yourself the embarassment of being in line at the tacobell drivethrough, spring a leak, clutch engage, and ram the person in front of you lol
Old Mar 26, 2006 | 09:08 PM
steven88's Avatar
Need A Light?
Its most likely the clutch line or slave cylinder somewhere....the fluid doesn't just magically disappear into thin air....its somehow leaking through the clutch hydraulic components...check the whole area and you should find your leak....
Most likely its the clutch line tho....its $25 shipped I believe for an SS one from BrianV...check it out
Old Mar 26, 2006 | 09:09 PM
MaxBoost925's Avatar
Drug Money
Check for leaks everywhere specially around clutch cylinder.
Old Mar 26, 2006 | 09:30 PM
Apparition's Avatar
Ichiban King
LMFAO I'd blame it on the meat in the tacos thats a popular thing to do these days.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
Need help
23
Oct 2, 2015 08:56 AM
carlosvq30
Sep 26, 2015 09:44 AM
