Driver side door hinge has a litlle slack sometimes clicking
I mentioned that after i cleaned hinges in coin wash. There was so much dirt so i sprayed everything with simple green and then with water. Before that there was some thick grease more like a glue
and probably that stuff kept the door silent so now i'm triying to find out what it was.
Does somebody has a clue what i can use. (instead of new hinges of course)
Thanks. I'd be really appreciate that.
![Crazy](https://maxima.org/forums/images/smilies/crazy.gif)
you can replace the door hinge, or if you want a cheap solution, you can slack the bolts retaining the lower hinge bolts (the ones that bolt on the body of the car) a little and put a steel washer (about 1/8 thick) between the car and the hinge...rescrew it and check if the door closes fine....mine is done that way and the door adjustment is perfect
boomerbrian
11-08-2015 05:10 PM
shaunkey1
08-18-2015 10:09 PM
