front pipe needs to be replaced
Old Mar 28, 2006 | 09:36 PM
blk96maxim's Avatar
need to replace this on my exhaust..2 quotes so far have been ridiculous ...500 and like 900 just for the part ..i have a 96 maxima se.. where should i look for this part..i really just need part of it rewelded or cut out and another piece welded in..
also whats a good brake pad to buy at advance auto parts.. thanks..i could use a lot of advice from someone really experienced with maximas..not sure if i want to put money into this car anymore..or buy something else.. email me at flash7791@aol.com if u dont mind..thanks so much
Old Mar 28, 2006 | 09:41 PM
NmexMAX's Avatar
dot dot dot ...
is a front pipe?
If it's the y-pipe you can get one for 160 or so.
tcrow31's Avatar
what do you mean by front pipe? are you refering to the pipe that comes from the front exhaust manifold?? if so why dont you just get the whole y pipe its a whole lot less than than either one of those price that you gave.
Old Mar 28, 2006 | 09:47 PM
ManualMaxima's Avatar
5th Gen till she dies!
maybe it is the cat(which is not front), or maybe it is the y and the flex is messed up.
Old Mar 28, 2006 | 09:52 PM
NmexMAX's Avatar
dot dot dot ...
Until we get a response...does anyone else want to play the guessing game...
Old Mar 28, 2006 | 09:53 PM
blk96maxim's Avatar
its the first pipe that comes out of the engine..and it connects in two spots to the engine.. i cant believe they will lie that bad about a friggin part ..they called it a front pipe ..midas and another garage
looks something like that i think
Old Mar 28, 2006 | 09:54 PM
blk96maxim's Avatar
ok..that picture didnt come out right ..my bad
Old Mar 28, 2006 | 09:59 PM
NmexMAX's Avatar
dot dot dot ...
Does it connect to the engine (exhaust manifold) or does it connect to the exhaus manifold... From that poor picture it looks like it is the y-pipe.
So how did you discover you need to replace this item...whatever it may be?
Old Mar 28, 2006 | 10:05 PM
blk96maxim's Avatar
my car failed the virginia safety inspection...the guy heard a leak..they put it up on the lift..and he pipe was cut and welded in an area a few feet back.. so the weld has holes in it and exhaust is leaking out... the car has 167,000 miles on it..needs new rack and pinion, brakes, rear right window is off track, new cv boots, new front axel probably, and last butnot least..i bought this car used with motegi rims.. the key for the lugnuts broke yesterday at midas..so the brakes are shot and i cant get the tires off the car to fix them til i get this part.. and motegi has no idea what im talkin bout with the part i have and the code on it.. so some dude thinks he can order it and it will fit.. if anyone wants me to explain it better ..email me or call 240-606-7185.. thanks guys.. i could use the help
Old Mar 28, 2006 | 10:09 PM
blk96maxim's Avatar
found cattman y pipe for 350 online ..that has to be the part
http://www.sportcompactonly.com/prod...tm_medium=shop
Old Mar 28, 2006 | 10:10 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by blk96maxim
help
... ... Might want to inspect your next purchase a little more carefully.
Old Mar 28, 2006 | 10:14 PM
blk96maxim's Avatar
sorry dude ..i cant crawl under my car with a camera..and i bought it used in 2002 .. and there was nothing wrong with it..its basically 11 years old ..dont appreciate u tryin to make me feel like an ***
Old Mar 28, 2006 | 10:29 PM
NmexMAX's Avatar
dot dot dot ...
The reason I ask for a picture is so that I can see if your car has an aftermarket y-pipe or if its stock. They look quite different.
If some dude thinks it will fit and do it for you, by all means, get it fixed. Your car sounds as if it is neglected.
I have wheel locks on my car, and the wheel locks are not wheel brand specific, so your call to Motegei would seem to be a waste. Your cv boots/axles can be fixed at the same time with a new set of axles since they come with boots.
For a quick bandage you can have someone weld the holes and fix it temporarily... or buy a y-pipe for less than 200$ from various vendors.
Old Mar 28, 2006 | 10:39 PM
blk96maxim's Avatar
im goin on a biz trip tomorrow..i will take a pic once i get it up on a lift again.. im willing to bet its stock ..because it was fixed the cheap way previously by the owner before me ...the pic wont be crystal clear cuz it will be from a camcorder with built in digi cam..not high quality.. sounds like i can cut my costs in half easily.. which means i can keep this car and not buy a new one ..thanks
Old Mar 29, 2006 | 08:06 AM
keb1209's Avatar
Definitely get an aftermarket front pipe (aka y-pipe, aka f-pipe), you'll cut your costs in half and gain a few extra horses....
stromm
Aug 27, 2015 04:13 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
Samedi
Aug 12, 2015 01:54 AM
