Installing gauges, need help
Old Mar 29, 2006 | 10:33 AM
ancientwiseone's Avatar
I just bought some indiglo gauges and I was told to wire the power to the headlight switch, I have no idea where to wire it onto in the headlight switch because there are so many wires. Can anyone refer me or help me out on which specific wire to wire the gauges to. Thanks
Old Mar 29, 2006 | 09:37 PM
bump..........
Old Mar 29, 2006 | 09:48 PM
99grnmaxgxe's Avatar
Sorry I can't be much help, but if you look in the How-To stickies they have some stuff on gauges there.
Old Mar 29, 2006 | 10:01 PM
VQPower702's Avatar
I tried wiring some indiglo gauges i bought from ebay one time to the LED light dimmer (i think thats wat its called), it worked for a while, then my gauges just completely stopped working. I think it culd b the gauges, but you could try connecting the wires to the LED light dimmer, but i'm not sure if that's where you're supposed to connect them..?
sorri i can't b much of help to you either
Old Mar 30, 2006 | 06:35 AM
NmexMAX's Avatar
dot dot dot ...
I tapped into my RPM power switch
Old Mar 30, 2006 | 08:35 AM
kkw1004's Avatar
if you go to #47 in 4th gen ***s sticky, you will find all wire diagram.
I did mine too and it is fairly easy
good luck
Old Mar 30, 2006 | 08:41 AM
Digitized's Avatar
2 threads for same issue?
check the sticky number 47 like KKW1004 mentionned... stickies are you friends!
Old Mar 30, 2006 | 08:50 AM
ManualMaxima's Avatar
5th Gen till she dies!
wire the power to the light on the dimmer switch, i am not 100% sure but i think it is the wire with blue on it.......then just ground it to one of the chassis points behind the cluster
97_GXE
20
Sep 17, 2015 08:12 PM
BrandonCause
Sep 14, 2015 10:41 PM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
asianstyle
Sep 10, 2015 11:30 AM
