Intake, Yes or No?
Old Mar 30, 2006 | 02:23 PM
LTU_max's Avatar
Intake, Yes or No?
I recently installed a short ram intake in my max, no other performance mods at all. The sound is very loud when at WOT, and also makes nice sounds when doing regular driving. My question is, does the short ram intake lose any power, I know it's good for top end, what I read from the stickies, and it also said "it's the best of both worlds." Now when I drive I can't chirp 2nd gear anymore, and I also took out the subwoofer box and everything else. Does this mean the intake lost power? I might put back my stock intake, since there's no noise, and might get my power back for chirping 2nd. What do you think?
Old Mar 30, 2006 | 02:27 PM
96customax's Avatar
Go for it...later
Mxrider52's Avatar
I support for what?
I have a Frankencar midpipe with a K&N popcharger and I cant chirp my tires but I get lots of torque steer which is better then chirping.
Old Mar 30, 2006 | 02:35 PM
Trajiksmax's Avatar
Proud Maxima Owner
I currently have a K&N short ram filter, and 19" lunkers (w/ tire weigh about 60+ lbs) on my ride chirping 2nd is not a problem. Yes, the intake will hurt your low end TQ. It's all on what your personal preference is. **Just a heads up chirping gears is not really good for your drivetrain. Wouldn't you rather have your tires hook up and pull hard?
Old Mar 30, 2006 | 03:13 PM
99grnmaxgxe's Avatar
Yeah you'll lose power especially with the summer heat coming. I would keep it b/c I like the sound and how it gives the engine some flavor.
Old Mar 30, 2006 | 03:35 PM
LTU_max's Avatar
What mods do you have?
Old Mar 30, 2006 | 03:37 PM
NYC32798's Avatar
I got a short ram and I have no problems chirping 2nd. If anything I gained a little bit pairing it up with the y-pipe. I love the sound it makes. I think sounds better than most exhausts on ricers in my opinion.
Old Mar 30, 2006 | 03:43 PM
f550maranello2's Avatar
YOU WILL LOOSE BOTTOM END TORQUE... PERIOD!!!!
the best intake is the stock intake.... with a clean 6$ filter
Old Mar 30, 2006 | 03:44 PM
Trajiksmax's Avatar
Proud Maxima Owner
Performance Mods: Warp Speed Y-pipe, Warp SS B-pipe, Unorthadox UDP, Stillen short ram intake.
Old Mar 30, 2006 | 06:07 PM
LTU_max's Avatar
That y-pipe I'm sure helps you chirp those big wheels Me with only my intake it doesn't chirp anymore, so I'll probably hold off on the short ram until I get the y-pipe, because I like quiet
Old Mar 30, 2006 | 06:11 PM
Supermax95's Avatar
take off the aftermarkter midpipe.....place the cone filter on the stock intake piping....thank me later
Old Mar 30, 2006 | 06:15 PM
LTU_max's Avatar
So this keeps the low end torque?
Old Mar 30, 2006 | 07:48 PM
You will still some low-end, but not as much. There was a test that proved that aftermarket midpipes lose more low-end when compared to the stock midpipe.
Old Mar 30, 2006 | 07:50 PM
D-Bo's Avatar
Droppin logs
Popcharger FTW
Old Mar 30, 2006 | 07:56 PM
devilz05's Avatar
Shift_3.0
When summer rolls around you will be crying to get that torque back, and if you have your a/c blasting, FOGEH ABOW ID! lol
Old Apr 1, 2006 | 01:19 AM
Supermax95's Avatar
yes, all your doing is replacing your stock filter with a cone filter....no low-end loss, better intake flow and better sound. You might want to consider getting a k&n filter with velocity stack....
Old Apr 1, 2006 | 02:17 AM
happyricefob's Avatar
V^___^V
i have bomz short ram + gen1 JWT filter and it's working out great
Old Apr 1, 2006 | 03:13 AM
Fulltone74's Avatar
The Airbox might be considered a weak link... but consider that the intake snorkel is actually somewhat useful. Notice that the shape somewhat converges towards the bottom of the intake box -- somewhat like a velocity stack.
Such things aren't even worth thinking about until you are past 5000rpms, and even then, its not really more than 5Hp difference out of 190Hp stock. And under 4000rpms, the results are virtually identical to stock. It wouldn't even make 1/10th of a second difference in 0-60mph.
The reason people think the aftermarket intakes are better is mainly because they SOUND faster, not because they really are faster.
Old Apr 1, 2006 | 09:30 AM
sonicrunch's Avatar
unless you have a lot of other mods, leave the intake stock.
Old Apr 1, 2006 | 09:45 AM
MDeezy's Avatar
why hasnt anyone suggested a belt driven intake
Old Apr 1, 2006 | 10:04 AM
Edwinsmax's Avatar
I just want to know one thing which is a better CAI from the maxima over all
Old Apr 1, 2006 | 11:14 AM
95bluse's Avatar
Hmm..must be spring...maxima.org is again sprouting intake threads.
My .02cents...leave it stock....you'll chirp your tires & have your passengers will never know how fast you're going. Then you can just grin & point to the speedo
Old Apr 1, 2006 | 11:28 AM
nart86
wow, you guys make the maxima sound like an m5
Old Apr 1, 2006 | 12:39 PM
maxima775t's Avatar
I've read up on most of the discussions about the stock vs. aftermarket intake, and I had originally decided to keep the stock one, but I saw someone mention a "K&N Filter with Velocity Stack" and say it's similar to the stock intake... but is it any better? Within a month I should have a new catback dual exhaust and I may or may not go with a new (lighter) flywheel, so there's that to factor in too. I'm very pleased with the stock intake, but if there's anything better out there I'd love to get my hands on it. Thanks.
Old Apr 1, 2006 | 12:50 PM
BigLou93SE's Avatar
That, or exhaust driven....I can only imagine...
Old Apr 1, 2006 | 12:55 PM
MDeezy's Avatar
Best two intake for our cars. . . dont know why people waist there time with filters and new cones
edit: I got it. . . get a VARIABLE intake show them all how its done!!
sorry I'm of no help today
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
