car doesn't get enough throttle when starting? check this out!
Old Apr 5, 2006 | 04:22 PM
busterdawg22's Avatar
Too obsessed
When I start my car, especially when the engine is already warmed up, it starts up fine and then the RPM's drop down and it stalls. If I give it a little gas for a second when i start it, it idles fine and runs fine. There's no problem with the way the car drives or runs, just when it starts. And it's not like it starts badly either, it just needs to give itself more throttle or something at the beginning. one guy i talked to said there is a valve or something that controls that? anyone know what it is?
fyi: i have a brand new IACV, alternator, battery and starter
Old Apr 5, 2006 | 06:39 PM
ChasMan's Avatar
Common problem.
Mine did this when I got it.. Changed the oil, put in a new PCV Valve and cleaned the throttle body.. Now it works fine.
Old Apr 5, 2006 | 07:57 PM
Too obsessed
what is the PCV valve? what does it do? i've had the oil changed pretty recently, so it could be the pcv valve
Old Apr 5, 2006 | 08:48 PM
tcrow31's Avatar
Mine does it and i have a bad coil pack. That valve that you are refering to is the IAC valve. If you look in the "how to" stickies itll tell you how to clean it
Old Apr 6, 2006 | 06:49 AM
Too obsessed
I have a brand new IAC valve... it doesn't need cleaning. any other ideas?
Old Apr 8, 2006 | 10:04 AM
stp4ever's Avatar
check for TPS , air temp sensor ,fuel filter and coolant temp sensor
Old Apr 8, 2006 | 07:55 PM
spddracer's Avatar
Also check and make sure you are getting a start signal to the ecm during cranking. If your ignition switch is going bad it can cause you to loose the start signal and cause hard starts/stalls right after cranking ect.
Lakersallday24
Jun 16, 2019 01:35 AM
schmellyfart
Sep 25, 2015 04:47 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Samedi
Aug 13, 2015 04:05 PM
acw
Aug 13, 2015 12:50 AM
