wobbly crankshaft pulley...
I put an aftermarket crankshaft pulley on my car and it seems to wobble at idle is this normal ? However when i open the throttle a bit it levels out. Is it not tight enough ? Is it the belt ? I had this pulley on my last motor before i did the DE-k engine swap and i dont remember this happening. Im 100% positive the pulley works on this motor. Im just curious as to why its wobbling a bit at idle. I think it may be the belt, maybe too tight ?
well i put a movie up for you guys i dont know if it will help you can kinda see it wobble a bit.
http://media.putfile.com/wobbling-crank-pulley
Wobbling anything under the hood is never a good thing...Make sure it's bolted down correctly, and you torqued it down properly. Everyone on here seems to just 'snug things down', I've yet to see anyone use a torque wrench on anything. A good $50 investment, IMHO.
i believe the torque spec is 140. ANd i dont think its any where near that. I think its at maybe 70~80 at best ill give it a crank with my torque wrench hopefully that will fix it.
you know, a while back I remember reading about a similar situation, but his pulley was a stock one and definitely wobbled. It turned out that it was his water pump. The shaft on it was bent. I'm guessing maybe your previous pulley wobbled too, and you didn't notice it until now? Just a guess, but worth consideration.
i searched a bunch of threads that all say 120~ 140 but only go up to 120 because the material is different.
Nothing that would cause a crank pulley vibration is likely to throw a code (unless it's REALLY off -- in which case you'll have some SERIOUS trouble).
Are you getting any coolant leaks? A bad water pump can cause a moving crank pulley. I should know....
Other than that, it might be a timing chain tensioner or tensioner guide.
so what do i do ? I dont think im missing a tooth on the signal plate i think i just chipped it :P
6spd4dsc
Mar 4, 2016 05:19 PM
hayne
Oct 5, 2015 11:53 AM
