Consult Software.
Old Apr 12, 2006 | 11:33 AM
MarcL's Avatar
Consult Software.
Hey,
I am working on a VQ35 conversion using the 96 ECU. Of course, I am having trouble getting it running and though I could make use of the CONSULT port to diagnose.
I see a number of cable/software packages on the internet, but wanted to get some reccomendations from people with Maxima experience.
So.. Any suggestions?
Thanks,
Marc
Old Apr 12, 2006 | 01:00 PM
oldngivout's Avatar
Willing to learn
Are you talking about getting the 3.5 running with the 96 ECU and the 3.0 timing and intake components? Of course you know that the 96 ECU will not support the variable intake or cam timing.
Old Apr 12, 2006 | 01:02 PM
2 MaXiMuS 4's Avatar
Maxima.Org's Official Lurker
why not just get a VQ35 5th Gen ECU?
Old Apr 12, 2006 | 01:24 PM
MarcL's Avatar
Yes, I know. I converted all of the timing stuff to the VQ30, as well as the flywheel and other components as discussed in the "motor" forum on this site.
I did not know this was possible.. I was told the VQ35 ECU needs lots of "stuff" to operate.. Essentialy the whole rest of the car! If it is possible to use the VQ35 ECU, I sure did waste a lot of time and money making it look like a VQ30!
But still.. Anyone have a suggestion for Consult Link software?
Old Apr 13, 2006 | 08:02 AM
oldngivout's Avatar
Willing to learn
Yes you are correct. You will need most of the 3.5 car to make it work, so you did the right thing there.
As for the consult software, what are you trying to do? Just get the thing running correctly? Any generic scan tool will be able to help you diagnose sensors and things that may be causing your problems. After all, what you basically have is a 96 Maxima as far as the ECU is concerned.
Old Apr 13, 2006 | 08:10 AM
Jime's Avatar
I believe there are only 2 Consult I hardware tools available. I am using the PLMS and the other is the BlaZt,(edit after MarcL's post) functionally I believe they are identical. The OBDII there are dozens.
Currently I am using Nissan Data Scan which I believe is the best for Consult I. However I also have Conzult-SX, Ztalk, CalumSult and Tecu plus a couple for my OBDII reader as well.
Old Apr 13, 2006 | 08:17 AM
MarcL's Avatar
FWIW, I purchased this item:
http://www.blazt.biz/
I will report back how it works.
Old Apr 13, 2006 | 10:47 AM
mindlessoath's Avatar
sweet! any tips on using this Blazt for my maxima? what values should stay in between... like a max min value... things i shouldnt change etc.
Old Apr 13, 2006 | 10:58 AM
Jime's Avatar
I'm still playing but I wouldn't make any changes that you don't know the consequences. Although remember none of the changes you make remain after the vehicle is shut off, not like Consult II.
I particularly like the speed test 0-xx and now on the newest version of Nissan Data Scan 1.5 it has a xx-xx speed test so you can set it at whatever speed you want. Should be really good for comparing changes because you can use a rolling start so no variations in traction and because its starts and stops automatically there is no operator error for times.
Old Aug 9, 2006 | 02:04 AM
Infowire's Avatar
im not sure witch interface to get i think http://www.blazt.biz/ should work with my 1995 max.
heres my ports i got.
Old Aug 9, 2006 | 02:46 AM
liqidvenom's Avatar
brotherhood of tq
i have the same software as jime, and i got the cable from plms
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
torontoboy
Nov 15, 2002 07:23 PM
rcrdps
Mar 19, 2002 01:36 PM
yongjun
Feb 27, 2002 12:27 PM
