writeup for wiring ipod to bose sterio?
Old Apr 18, 2006 | 02:03 AM
evil_spork's Avatar
first, yes i looked through the FAQ's
i KNOW ive heard of this.. someone soldered a lead directly into their bose headunit for their ipod. im assuming they used the cd changer button on the headunit.
any links to the how to?
Old Apr 18, 2006 | 02:18 AM
nhaven's Avatar
http://forums.maxima.org/showthread.php?p=4083400
Old Apr 18, 2006 | 02:20 AM
evil_spork's Avatar
w00t!
thanks!
/thread
Old Apr 18, 2006 | 02:30 AM
nhaven's Avatar
no problem
Old Apr 18, 2006 | 03:28 AM
BlackMaxdout's Avatar
It's a real PITA trying to solder onto the tiny PCB board pins, but in the end it works. I've done it to my '96, and it's really neat.
Old Apr 18, 2006 | 12:38 PM
evil_spork's Avatar
trust me ive soldered harder things than that. exposed pins covered with solder like those are a cakewalk to solder to.
now... soldering to a dot the size of the point of a needle thats laquired over... that, is hard.
soon as i find a bit of time(probably soon) ill do it and make a thread.
Old Apr 18, 2006 | 02:08 PM
MorpheusZero's Avatar
It's a bit of a PITA, but it's doable. If you want good ipod connectivity then you should get something like the belkin ipod car charger with aux output, makes it much cleaner if you're willing to hide the wires and such.
Old Apr 19, 2006 | 01:02 PM
evil_spork's Avatar
i was planning to use my actual ipod dock with the ipod connector on the back and a line out. then i can use any ipod i want minus a shuffle... which would have to dangle.
Old Apr 19, 2006 | 02:59 PM
yeah thats fine, but the line levels are still going to be different. The belkin charger has a line out and built in amp so that you don't need to crank the volume on the headunit to hear anything. Then it's all rca jacks from there. You could do it all internally and hide it in front of the shifter inside the dash. Then run left and right audio, and the charger portion to the iPod dock.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
