BBK Finally Installed
Old Apr 19, 2006 | 07:11 AM
MaximaSE96's Avatar
Maxima Owner
Finally after a few issues and spacing problems they are on.....because my wheels offset is so retarded I had to use 20mm spacers....the fitment of the brackets wasnt as great as i hoped but they seem to be ok now...this is the Blehmco 12.6" rotor kit BTW
Old Apr 19, 2006 | 08:05 AM
WielkiWaac's Avatar
MaximaDriver
daamn!!!
that stuff looks crazy.
congrats man!!
Old Apr 19, 2006 | 11:41 AM
maximariceboi's Avatar
nice.looks great man..im trying to find some 300zx calipers as of now. how much did u spend totally for the whole swap?
Old Apr 19, 2006 | 11:59 AM
BigLou93SE's Avatar
Looks great bro - any reason to not have gone with Cobra rotors? You seem to be making a lot of progress lately on your car, nice job!
Old Apr 19, 2006 | 12:48 PM
Kevlo911's Avatar
Kevlo for President
Good job man
Old Apr 19, 2006 | 12:55 PM
papasmurf's Avatar
Honda Convert!
Hey are those Enkie RSF-2's if thats the case fdo you think a 12.5mm spacer will work or not. I have all the parts for the bbk on the way and I have order 12.5 mm spacer for the front and a 5mm spacer for the rear, and also did you need longer studs?? and what size studs did you get and from where?
Thanks, Bruce
Old Apr 19, 2006 | 12:57 PM
MaximaSE96's Avatar
Maxima Owner
the main reason i wnet with the maxima rotors is because hub bore size and more pad contact....if u look closely at the cobra kits about 3/16"-1/4" of the upper portion of the pad does dont make contact with the rotor....with these rotors that issue is jaut about 1/16" if any.....plus i would ratehr have a Nissan replacement part on my car than a Ford part...
and yes the past few weeks have been busy in my parents driveway auto-x starts this weekend so now i am just fine tuning...although i need to replace an axle soon.......
as far as spacers go....i think a 15mm spacer will work for my application but it really all depends on ur particular offset.....when i did an apporximation measurement like Matt says on his webesite it was close so i opted to be safe and get the a lil larger....the studs came with the spacers they are H&R spacers......i will be running 5mm spacers in teh rear in a few weeks....i ordered them from optionsauto.com
cost of swap goes as follows
200 for brackets and lines from mattblehm.com
75 for Hawk HPS Pads
i got a deal on calipers from a friend I paid 80 for the pair...if u goto Autozone/NAPA/Advanced pay 80 for each side or more depending on brand of reman co. and if u have cores or not. i suggest try ebay first.
120 for rotors
120 for spacers
600 total give or take for an awesome BBK.....Brembos 13" kit goes for 1700 bux for 1pc rotors and 4 piston calipers.....SSBC 2 piston calipers and 12" rotors goes for 800
Old Apr 19, 2006 | 01:03 PM
Jeff92se's Avatar
I'm needing a caw
Um there's no way that there is that much overhang. My experience is that pad overhang is 2/16" at the very most. Any perceived "loss" in pad contact is more than made up using a rotor that's 0.4" larger.
It's nice to have all Nissan stuff. I can understand that. But Nissan/Ford (actually everyone) don't make their rotors. They all subcontract that part to one of the many makers that supply OEM parts to them.
I'm not condoning one kit over the other, just want to make sure the correct information is out there.
Old Apr 19, 2006 | 01:09 PM
MaximaSE96's Avatar
Maxima Owner
my measurements may be a little off but i am just lookign at my scales in front of me and trying to remmeber pictures....and i know most rotors are contracted out but they are made to NIssan Ford Chevy specs....
Old Apr 19, 2006 | 01:13 PM
Jeff92se's Avatar
I'm needing a caw
Yes, the measurements are little off. But when your wrong buy a few 16ths, it seems like ALOT of difference. Which there isn't. In theory, because Matt's kit uses close to a .5" smaller rotor, you can get the caliper down closer to the rotor. But it's really how close one chooses to mount the caliper body to the top of the rotor. I chose as little wiggle room as I felt comfortable with. Especially with people buy rotors from all over the place.
I really doubt Nissan/Ford specs on rotors are all the different. Especially when the 13" Ford cobra rotor is on Ford's premier muscle car and the maxima rotor is from Nissan family sedan series.
Old Apr 19, 2006 | 01:16 PM
MaximaSE96's Avatar
Maxima Owner
well whatever i am not trying to mock or discourage anyone from buying ur kit...cause believe me matts brakect had a few flaws...i can rant about...he asked y i opted for matts kit and i told him....and on a side not IMO its sad ford premier muscle car has almost the same size brakes as a family sedan
Old Apr 19, 2006 | 01:27 PM
Jeff92se's Avatar
I'm needing a caw
Um wha?? Think about this.
Ford put 13" rotors and big 2 piston Baer calipers on their cobras back in 1993. .
What did Nissan have for their sedan in 1993? 11.x" rotors. Plus the maxima got only single piston calipers. The biggest sedan that still used the single piston caliper.
Old Apr 19, 2006 | 02:12 PM
Zack342's Avatar
Can you elaborate? i am planning on purchasing Matts brackets tomorrow. What were the fitment problems?
Old Apr 19, 2006 | 05:38 PM
Zack342's Avatar
Non brembo Z' use this 12.6x1.1 rotor, my brothers M45 uses this 12.6x1.1 rotor and so does the altima ser.
Old Apr 19, 2006 | 05:55 PM
Iron Scimitar's Avatar
Tha Snatcher
Jeff's brackets are on the money
Old Apr 19, 2006 | 06:17 PM
Jeff92se's Avatar
I'm needing a caw
Yup and still used a single piston caliper. The 03 Gs use this rotor. And they worked so well that infiniti issued a warranty revision to replace the pads/rotors free for 3 yrs/36,000 miles. My 03 brakes are excellent though.
Old Apr 19, 2006 | 06:19 PM
MaximaSE96's Avatar
Maxima Owner
the biggest issue i had with matts brackets was the powercoat was in the holes and i had to drill them out to get the bolts to go through...also there are multiple ways the brackets will bolt up and u wont know if its right until u get everything together...i fu l ook at other peoples installations their calipers are way off compared to mine and matts website....and jeff i am not picking a fight but Ford has to outsource their brake development to BAER to get decent brakes....and regular mustang not Cobra Rs had Escort GT brakes in the early 90s....mean while Nissan was using 4 piston 30mm thick rotors on the Z in 1990..adn 2 piston rear calipers....sure they werent 13" but i will bet Zs stopped better than mustangs.....and Jeff maybe in a year when i need to do brakes ill buy ur brackets to see which ones are actually better....but like i said i chose matts for my own particulat reasons...IMO both are great value compared to Brembo or SSBC or Wilwood
Old Apr 19, 2006 | 07:05 PM
MAXRB8's Avatar
When I had my 4th gen I chose to go with Jeff's brackets and hub rings as there was just way more options ( and competiton = cheaper prices) when it came down to purchasing 13" cobra rotors as these rotors had been available for over a decade. I did end up purchasing the SS brake lines from Matt so thanks to both of these guy's efforts we all reap the rewards of an excellent BBK upgrade for a bargain price!
Old Apr 19, 2006 | 07:28 PM
Jeff92se's Avatar
I'm needing a caw
The Z32 guys complained about their brake performance. The calipers were good. But they stuffed the nice calipers under a 16" wheel with tiny rotors. Meanwhile the SupraTT had 17s and superior brakes. I'll have to look it up but I'm going to say the Cobra stopped shorter than the Z32. Once you have gone to Matt's or mine, just stick w/ it. Both r fine
edit: 03 cobra 60-0 time is 121 ft. Not bad for a 1993 Ford
Old Apr 19, 2006 | 07:45 PM
Zack342's Avatar
The G35 coupe and M45 use this setup with a 2 piston caliper. I know for a fact. When i was helping my brother take off his winter wheels i saw them. they are more than sufficent for that car so i think on a lighter maxima they will be more than what i need.
Old Apr 19, 2006 | 07:48 PM
Jeff92se's Avatar
I'm needing a caw
That's why I mentioned the my car(sedan). Matt's kit is fine. My kit is fine. That was never in question
The G35 coupe and M45 use this setup with a 2 piston caliper. I know for a fact. When i was helping my brother take off his winter wheels i saw them. they are more than engine for that car so i think on a lighter maxima they will be more than enough.
Mar 12, 2020 12:06 AM
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
