oil pressure sensor
Old Apr 21, 2006 | 10:09 AM
jaemax's Avatar
oil pressure sensor
Does anyone know the location of this sensor? At start up my oil light flickers about 2 - 3 times and then goes away. I am hoping is due to the oil pressure building up in the morning after sitting. However, lately since driving almost 100 plus miles per day to and from work, when engaging the clutch to change gears, the light starts to flicker as well. I need to check this out before going forward. Anyone have any ideas?!
Old Apr 21, 2006 | 10:15 AM
diy_dreamer's Avatar
it's by the oil pan. If you are facing the front of the car and the oil filter is to your right, then socket should be in your face. There's a cable to connect's to it.
Old Apr 21, 2006 | 10:23 AM
DcMaN's Avatar
why dont you start by checking how much oil is in your car ? If its right on the money then i suggest you replace the oil pressure sending unit.
Old Apr 21, 2006 | 11:33 AM
jaemax's Avatar
give me a lil credit man... LOL!!!
I did check and have enough oil... I may see if it is the oil pressure sending unit. Will run a check on it..
Old Apr 21, 2006 | 11:40 AM
1FSTMAX's Avatar
i would check the oil pressure and make sure it's up to spec..
Old Apr 21, 2006 | 04:14 PM
ti2tmax's Avatar
Has his VINs memorized
it's very close to the pass axle on the (backside of the) oil pan. from napa its part number OP6115 and costs 10.80 before tax.
Old Apr 21, 2006 | 04:48 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
make sure to use thread tape when replacing it!
gustavison
Oct 4, 2015 06:50 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
