Common 4th gen problems, is timing chain a problem?
Old Apr 23, 2006 | 12:31 PM
99MAXSE-L's Avatar
So i've already replaced an ignition coil in my 1999, but what else is a common problem??? My friend had to replace his timing chain thats costed like 2grand. I have 67,000 miles, but i have yet to hear about timing chains giving up from ppl on the org.
Old Apr 23, 2006 | 12:45 PM
Armelius's Avatar
267k miles same chain.
Old Apr 23, 2006 | 12:46 PM
diymaximakid's Avatar
its the tensioner that goes and your friend got ripped off hard
Old Apr 23, 2006 | 01:05 PM
Mr Willis's Avatar
172,000k same color, trim and year. Ours are special. LOL
Old Apr 23, 2006 | 02:47 PM
99se5speed's Avatar
SHIFT_up
rofl 2grand for a timing chain...it should be somewhere around 200 i'd say cause you have to lift the motor up somewhat to put on the chain. As for them giving out you would definetly fell if it's bad.
Old Apr 23, 2006 | 03:20 PM
njmaxseltd's Avatar
Timing chain tensioners are a common failure item on early 4th gen models. 97 and on have no issues with the chain or the tensioner. They should last the life of the motor.
Old Apr 24, 2006 | 08:33 AM
NissanMan97's Avatar
Read some of the stickys in the 4th gen section. It will point out commons problems and the easiest way to fix them, but as for the timing chain like njmaxseltd said they should last the life of the motor.
B
Old Apr 24, 2006 | 08:56 AM
99grnmaxgxe's Avatar
From the stickies:
Does my 4th gen need a timing belt replacement?
No.
All VQ equiped Maximas (1995 - on) use a dual stage timing chain. This needs no periodic maintenace or replacement. It is designed to last the life of the engine. This is a very good thing.
Your friend got raped for that price, he could of gotten another car for that $.
Old Apr 24, 2006 | 09:09 AM
Dexter's Avatar
Tensioner does go bad around 100K for 95-96 Maximas and if not repaired quickly it will screw up the timing chain...
it is expensive to repair (around $600-800) but YOUR FRIEND GOT RIPPED OFF HARD!
Old Apr 24, 2006 | 09:22 AM
99MAXSE-L's Avatar
the chain blew on his car causing more problems i believe.
I have a 99, my cars been making funny sounds, i hope its not the tensioner as some of you have pointed out
Old Apr 24, 2006 | 10:37 AM
Bobo's Avatar
Are you saying it is $600 to $800 to replace the tensioner?
Old Apr 24, 2006 | 10:44 AM
Dexter's Avatar
I got quoted 833 for tensioner + timing chain @ the dealership.
And they're the ones who'll most likely charge the most.
Lakersallday24
Nov 7, 2024 07:31 PM
maxinout93
Oct 27, 2015 01:29 PM
Finkle
Sep 27, 2015 09:53 PM
kirkhilles
Aug 8, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
