Cobra BBK Done
Old 05-04-2006, 02:57 PM
  #41
chillin014's Avatar
oh yikes you have to get the holes redrilled. what year cobra rotors are they? im considering just sticking with the 04 maxima rotors after all the modifying that looks like needs to be done.
chillin014 is offline
Old 05-04-2006, 04:01 PM
  #42
Maximus_95's Avatar
well just redrilling it to 114.3 x 5 pattern. is not a big deal. as you see on the picture above, there are extra holes, the smaller ones is what you will be using. after that, that's all you need to do it fits in right perfect!
cobra rotors are bigger than the new maxima's so that's why i went for that one, but if you dont want to hassle with it, i guess the maxima rotors will work just fine.
Just remember.....redrilling is not so much of a hassle, all you gotta do is get it done that's all.
good luck.
Maximus_95 is offline
Old 05-04-2006, 04:43 PM
  #43
chillin014's Avatar
oho yeah? whered you get it redrilled? and what year rotors are those? i dont see why i'd need a hub ring. i could just use maxima spacers with those, couldnt i?
Old 05-04-2006, 04:48 PM
  #44
Project Ruby......
4DRSpeed's Avatar
You need a centering ring to center the rotor to the hub. It's kind of like hub centric rings to help center your wheels to the hub. This help centers the rotor.
4DRSpeed is offline
Old 05-04-2006, 04:59 PM
  #45
chillin014's Avatar
How come the thread starter didn't have to? I guess I gotta go look at my wheel to understand.
Old 05-04-2006, 05:47 PM
  #46
G4nismo's Avatar
nice rotors, need to do mine as well, and suspension
paint the calipers flaming purple
G4nismo is offline
Old 05-04-2006, 07:38 PM
  #47
Maximus_95's Avatar
chillin, when you redrill the rotors, you dont really need to get the center rings.
you need the center rings if you dont redrill since the whole of the rotor for the cobra is a lot bigger, then rotor is just going to sit down but with the redrill, the rotor will sit just like our rotor on the maxima since it will fit well.
people recommend to use the ring, but i didn't and its all fine as it is from the way i see it.
Old 05-04-2006, 08:28 PM
  #48
chillin014's Avatar
ahhh i get it now. redrilled takes all the "slack" out of the holes. so yeah i guess its not a problem.
so WHERE did ou get them redrilled? and what year are those from ?thanks for the help
Old 05-05-2006, 04:15 AM
  #49
Zack342's Avatar
good luck.
Excellent. I think this is what i will do.
Zack342 is offline
Old 05-05-2006, 08:38 AM
  #50
Maximus_95's Avatar
chillin, these cobra rotors i believe it runs from 94-04 or something like that and any of these years cobra rotors will work just fine. they are all the same size.
and the redrilling, i got it done from the company i bought the rotors from. you can ask if they can redrill it for you, it shouldn't cost more than $15 bucks.
or you can take it to a machine shop that does rotors, they can do that for you too.
Old 05-05-2006, 08:55 AM
  #51
I'm needing a caw
Jeff92se's Avatar
Just for the record, I'd get the rings. I doubt the machine shop could really bring the hole tolerances that close to center the rotor perfectly. These rings help accomplish this.
Jeff92se is offline
Old 05-05-2006, 09:03 AM
  #52
Maximus_95's Avatar
yeah i know the rings are recommended but its ok for me.
i actually have the rings but when i put the rotor on, it fit weird....maybe because my wheel hub was a little rusty?
Old 05-05-2006, 09:08 AM
  #53
I'm needing a caw
Jeff92se's Avatar
It didn't fit all the way on? Yes, if the hub is all rusty, you need to scrub or scrape all the scale off.
Jeff92se is offline
Old 05-10-2006, 03:48 AM
  #54
Zack342's Avatar
you know when i put the rings on, there was just way too much space in between the bracket and my caliper so i did not put them on.
i did get the rotor redrilled though, and it seems to fit well.
im curently running 17x7.5 on it and i was very skeptical if it would fit or not, and it does fit (thank goodness)
for everyone that doesn't know if it would clear their wheels or not......17's is the minimum for this kit to fit under the inner barel of the wheel. but clearance of the spoke is also another thing.
doesn't matter what offset your wheels are, because if the spoke design is off, it will not fit. do a lot of research before putting these on!!!
the whole set up. i dont remember how much it cost, i got the calipers with the 300zx rotors first, and with the new rotor and brake pads, cost me about 160. brackets i had long time ago. so i really forgot how much i spent total, but ball park....maybe $600-$700?
Do you know what the offset on those wheels are?
Zack342 is offline
Old 05-10-2006, 08:31 AM
  #55
Maximus_95's Avatar
i believe the offset of my wheels are 35+....
i think that's what it is.
Old 05-10-2006, 09:49 AM
  #56
Zack342's Avatar
Are you positive I am really confused now from what i found Enkie doesn't make a 17x7.5 RS5 with a 35mm off set in a 5x114.3 bolt pattern.
http://www.enkei.com/Performance%20specs/rs5.html
Can you check because I may get these wheels and they are $142 each.
they do make a 17x7 with a 40mm offset in a 5x114.3 bolt pattern. The reason I am asking is i purchased G35 sedan wheels in a 17x7 with 40mm off set and i am trying to figure out if they will clear this upgrade.
Zack342 is offline
Old 05-11-2006, 07:18 PM
  #57
Zack342's Avatar
bump it up
Zack342 is offline
Old 05-12-2006, 08:54 AM
  #58
Maximus_95's Avatar
bump it up
hey zack....i checked out the link and it is wierd,... i saw the sticker in the inner barrel of my wheel and it was written 17x7.5 im 100% sure....maybe they discontinued??....
Old 05-12-2006, 09:01 AM
  #59
Zack342's Avatar
one last favor. what size tire are you running 225? or 235?
Zack342 is offline
Old 05-12-2006, 09:31 AM
  #60
Maximus_95's Avatar
I think right now im running 235's. but my next tires will be 225's. that's supposed to be a better fit.
Old 05-12-2006, 03:04 PM
  #61
Project Ruby......
4DRSpeed's Avatar
Better fit? You actually may have 17x7s. 235s aren't really suppose to be run on 7" wide rims. I am running 235s on my 17x7s. 235s fit perfect on 7.5" wide rim.
4DRSpeed is offline
Old 05-12-2006, 03:38 PM
  #62
maximaintheface's Avatar
very nice. i need to get some new rotors.. im thinking of a bbk but i cant decide if i want to shell out the money.
maximaintheface is offline
Old 05-22-2006, 07:48 PM
  #63
Project Ruby......
4DRSpeed's Avatar
Finished my upgrade, and even with 20MM spacers, I think the inner "barrell" of my wheel is not designed correctly for this kit.
I have 17x7 Motegi DP6 42MM offset added 20MM spacers. And the front of my caliper to the wheel has less clearance than yours Maximus. I'm running Q45 calipers with Q torque arms. .
I'm not quite sure what I can do. I have credit card worth of space. The driver side is fine, the passenger side is not, the wheel weights touch. I may just have to get the wheel weights moved. I am not sure.
4DRSpeed is offline
Old 05-23-2006, 12:17 AM
  #64
Maximus_95's Avatar
see if you can get those weights added in a different area. is that the only place that does not clear/??
Old 05-23-2006, 06:27 AM
  #65
Project Ruby......
4DRSpeed's Avatar
Ya it appears so. It is TIGHT!!
4DRSpeed is offline
Old 05-23-2006, 07:38 AM
  #66
I like Maximas
vipervadim's Avatar
quick question:
what's the difference in weight of the 300zx rotor compared to the cobra rotor? compared to the 04 maxima rotor?
in all respects, the 04 maxima rotor sits much better than the cobra rotor on the 4th gen max.
kevlo911 has that setup.
vipervadim is offline
Old 05-23-2006, 08:48 AM
  #67
Maximus_95's Avatar
im honestly not too sure the weight differences. all i know is that the cobra will keep cooler since it is a bigger rotor.
Old 08-22-2006, 07:16 PM
  #68
Zack342's Avatar
what happened to the pics?
Zack342 is offline
Old 08-22-2006, 07:34 PM
  #69
Fire in the hole!
Chefasaurus's Avatar
Chefasaurus is offline
04-16-2020 05:15 AM
Quickgtp
04-13-2017 03:30 PM
maxfever1987
11-19-2016 08:01 PM
BkGreen97
04-02-2016 05:47 AM
Dave B
02-03-2001 10:47 AM
Quick Reply: Cobra BBK Done
