power antenna unit removal/install
Old May 9, 2006 | 12:23 PM
dipitydoo's Avatar
Is there a link to a how-to on removal of power antenna unit? I tried replacing the antenna mast, but it seems to be stuck and won't come out, so I need to take out the unit, unless someone has another suggestion. Thanx.
Old May 9, 2006 | 01:39 PM
kelster23's Avatar
Is it just sticking? If so, put some lube at the points where in contracts shut, like graphite or something of that sort. I only have to do that once every 6 months and it fixes the problem every time. Check out Haynes or Chiltons for actual replacement procedures. It's a good investment anyway.
Old May 10, 2006 | 07:03 AM
vvslavavv's Avatar
How did you try to pull it out? From what I remember when I replaced the mast, you have to turn the radio on to extend the antenna ... and pull it out while it is extending.
Old May 10, 2006 | 10:44 AM
dipitydoo's Avatar
My antenna was stuck, and the motor kept making noise to try to bring it up every time I started my car. The noise got annoying, so I disconnected the power antenna lead at the radio. The antenna stays stuck raised (though probably not all the way up). Do you think it will come out if I reconnected the power to the antenna and try to remove it while the motor is running?
chisam14
Nov 6, 2018 08:56 PM
gigabyte
Jan 6, 2017 06:05 PM
sliptap
Sep 30, 2015 05:57 AM
Max Nu-BE
Sep 28, 2015 10:25 AM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
