how to install 00VI???
Old May 9, 2006 | 05:30 PM
jvelos3's Avatar
okay...I know that there are a billion different ways to install the 00VI.
I am wondering if its possible to do with just the A33 upper IM with the 5th gen throttle body?
Do I need to use the 5th gen rear coils and valve cover?
Old May 9, 2006 | 06:41 PM
gtr_rider's Avatar
192.168.1.1
wow you really need to read up.. check All motor section
Old May 9, 2006 | 06:57 PM
86maxima96's Avatar
I Broke OT
uh, good luck doing it with the A33 upper IM. there are tons of posts on this. just look around in the 4th gen forum for starters.
Old May 9, 2006 | 07:00 PM
97vq30de's Avatar
word. you really need to read up. i'm not even an OG of .org and i know that i should researchbefore askin questions. hope you can find the right resources. 00vi is a great advantage to have..
Old May 9, 2006 | 07:03 PM
motocross416's Avatar
http://vqpower.com/gtrmax/00VI/
Old May 9, 2006 | 07:10 PM
2 Da Max's Avatar
Check out all motor section, they have tons of info there
Old May 9, 2006 | 10:35 PM
jvelos3's Avatar
Originally Posted by motocross416
Thanks...just what I was looking for
Old May 9, 2006 | 11:21 PM
DR-Max's Avatar
Another satisfied, spoon-fed, newbie.
Old May 9, 2006 | 11:37 PM
86maxima96's Avatar
I Broke OT
number 54,872 and counting
Old May 10, 2006 | 01:29 AM
jvelos3's Avatar
I read the write up...its incomplete...but i get the idea. and I read some posts...one in particular which tried the same set up I want to do...4th gen lower, 5th gen upper and throttle body and IACV.
So far I need to flip and drill the 4th gen lower IM, grind down the rear coil pack bosses and replace the pcv. Then work on the IACV and EGR.
Im confused on exactly how to drill the 4th gen lower...I know I have to flip it around. Also I read that I have to drill holes on the 00VI also?? and do all 8 holes have to be used...can I just use some of them??
Is it possible to use the 5th gen IACV...or do I need to get an adapter plate and use the 4th gen?
How about the EGR...do I just remove the vacuum hoses and plug them?
How about the TPS...will the 4th gen plug into the 5th gen tps or do I have to use the 4th gen tps?
I prefer to use the 4th gen lower and 5th gen IACV since it seems like the cheapest route. but will using the 4th gen lower hurt performance? Are the larger 5th gen injectors really needed?
I downloaded the 1997 and 2000 FSMs to figure out where the vacuum hoses lead to...this seems like the part that takes the longest to do.
And yes I admit...I am a newb.
Old May 10, 2006 | 06:50 AM
so I'm feeling nice this morning
http://forums.maxima.org/showthread.php?t=463248
http://forums.maxima.org/showthread.php?t=345720
MaxLife17
Jun 27, 2019 01:37 PM
t6378tp
Sep 29, 2018 04:27 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
