A few motor questions
Old May 12, 2006 | 12:52 AM
Umass021's Avatar
The motor in my 1995 gxe has just thru a rod. I found a motor with 67k on it out of a 1998 maxima. Will everything match up ok? Is there anything I will need to get before the motor gets changed? Anyone who has switched there motor or know anything about it please let me know how things turned out.
Umass021's Avatar
I would also like to know what the weight is on a maxima motor. Thanks.
Old May 12, 2006 | 06:21 AM
95GLEMAXX's Avatar
yea its the exact same engine, so it shud swap over. only thing is, some emissions things may be on the 98 engine that werent on ure 95.
Old May 12, 2006 | 08:09 AM
ChasMan's Avatar
I dont know anything about it but I wanted to suggest that it would be a good idea to put a new rear main seal on it perhaps before you bolt her down.
Good luck!
Old May 12, 2006 | 08:18 AM
DcMaN's Avatar
yes everything is the same minus the evap and EGR system. However i would suggest you locate a 2000~2001 De-k Maxima motor. As they are in the same price range. Since you are pulling the motor but its up to you. WWW.car-parts.com
Old May 12, 2006 | 08:34 AM
Umass021's Avatar
Would I need to get anything different if I got a de-k motor or would everything match up ok?
Old May 12, 2006 | 08:42 AM
Umass021's Avatar
Would I also need the computer? And is everything eles interchangable? I have stone racing headers on ym car now will those also bolt right up?
Old May 12, 2006 | 08:51 AM
Umass021's Avatar
What would I need for that?
Old May 12, 2006 | 09:23 AM
Biggs_02's Avatar
because there more hp coming out of that engnie then the 98
Old May 12, 2006 | 09:29 AM
Umass021's Avatar
So what do I have to buy to switch a 1995 motor to a 1998 motor?
Old May 12, 2006 | 09:41 AM
speed racer's Avatar
You should donate and start looking at the all motor forum for the DEK swap. There is alot involved with the sensors and perhaps the EGR. Most of it bolts up, but there is some slight fabrication if you plan on using the IACV. It all depends on how much down time you can afford and money.
Old May 12, 2006 | 11:39 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
All you have to buy is hte 98 motor. Anything that is different on the 98 can be swapped over from your 95.
Mar 12, 2020 12:06 AM
Maximan190
Dec 16, 2015 06:01 AM
hot04
Sep 18, 2015 06:14 AM
Johnny9595
Sep 3, 2015 05:18 AM
