Rear Brakes- AGAIN! how much $?
Old May 12, 2006 | 03:56 PM
FormorAccordMan's Avatar
THE DAMN CALIPERS ARE SEIZED AGAIN! I cant believe this ****. I changed them 25k ago and now the rear drivers side one is seized and getting really hot. I have to now replace a caliper have the rear rototrs cut, and have new pads put on. How much should I be paying? I am in Brooklyn New York keep in mind.
Old May 13, 2006 | 05:41 AM
Krannick's Avatar
is it the caliper piston that is seized or just the caliper bolts???
Old May 13, 2006 | 06:46 AM
NISMOPower's Avatar
I'd definately tear it appart and clean everything real well. Make sure all the guides are lubed....Cost wise, depending if your doing it yourself can vary. I don't know if anyone recommends just getting some caliper from the junk yard. Don't think they are too expensive there...Good Luck
Old May 13, 2006 | 07:01 AM
dgeesaman's Avatar
Maintenance Monster
I would not get them from a junkyard. If it's not the same caliper as the last one that seized, I'm not surprised.
But make sure it's not the e-brake cables dragging this time. I've dealt with both a seized e-brake cable and a seized caliper.
Dave
Old May 13, 2006 | 04:12 PM
96blkonblkse's Avatar
mine were seized so bad my rims were to hot to touch when on the highway. i got some from the junkyard which happened to be brand new for 25$ replaced my rotors, pads and calipers and its like new again!
Old May 13, 2006 | 06:08 PM
7jackmack's Avatar
Make sure it's not just a stuck or corroded caliper pin.
I had one stick after a pad change and rotor got smoking hot
just going around the block. Another time- pin got totally
corroded and froze in place - causing pads to wear on an
angle. It took over an hour for me to free it and put a new
pin in , but both rear calipers are still original and work fine
after 10 1/2 years - quarter million miles.
Old May 13, 2006 | 09:36 PM
BumbleB80's Avatar
I have an extra drivers side rear caliper, I am willing to sell it if you need it. My passenger side rear got stuck and I just brought both rear calipers from this guy. But I don't need the rear drivers side.
Old May 14, 2006 | 07:23 AM
BEJAY1's Avatar
Conecarver
Caliper maintenance should be a regular to-do item just like fluid changes, tire rotations, etc. Nobody told me either. Here's my maint writeup.
http://forums.maxima.org/showthread.php?t=469787
Old May 15, 2006 | 03:57 AM
FishyMan's Avatar
how do u know its siezed?
after driving jsut touching the plastic covers are pretty damn hot, the lug nuts as well.
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
bbsitum
Sep 11, 2015 04:55 PM
