Possible RSB rubbing issue...
Old May 18, 2006 | 05:47 PM
devilz05's Avatar
Shift_3.0
When I drive over bumps there is this extremely high pitch sound like metal rubbing on metal. I thought it was coming from the cabin but I checked all possible places. I thought it was the suspension but when I rock the car there is no sound. Its coming from somewhere behind me and Im thinking its my RSB rubbing against something. Has anyone experienced something like this?
This sound is driving me insane btw...
Old May 18, 2006 | 07:25 PM
99se5speed's Avatar
SHIFT_up
i also have a metal on metal scrap sound, i think it's coming from behind me aswell. I'm thinking the rear caliper froze or something.
Old May 18, 2006 | 07:52 PM
MaximA StyLeZ's Avatar
I just solved my problem today: Dont know if it helps, but i was getting a clunking noise like something hitting something, whenever i took a turn or went over bumps. I took out my back interior seats, and theres this piece of metal that connects to the armrest with two long screws. I took out that whole piece (it was about eight bolts) So when, I took that out, there was this open space between the trunk and back.
What I believe is that my RSB caused so much stiffness, so that piece of metal was forced to move or bend causing the knocking sound. Finally, it went away, thank GOD! Hope this helps.
I still have a squeaking noise coming from the back, but I think I have to grease the sway bar bushings.
Old May 19, 2006 | 04:01 PM
devilz05's Avatar
Shift_3.0
Its definetaly a squeaking sound that I have I guess Ill WD-40 the bushings and look around for possible culprits.
Old May 19, 2006 | 04:08 PM
no, i dont suggest wd-40 on the bushings. Get white lithuim grease from autozone or sumplace like that.
Old May 19, 2006 | 06:13 PM
Mxrider52's Avatar
I support for what?
If you look under your car you will notice a bracket running about a foot long under the exhaust in front of the axle beam. Your exhaust is hitting it when you hit a bump. My hanger is rusted off so I get alot of noise over bumps. I have come to conclude it is this bracket and exhaust hitting and my hanger is rusted off right there in that pic so i get alot of movement.
Old May 19, 2006 | 07:48 PM
devilz05's Avatar
Shift_3.0
I have a brand new catback and I remember the sound being there even before having the new exhaust. I have a feeling its the RSB rubbing in some way, nevertheless I will check everything out when I paint my calipers. Thanks!
Old May 19, 2006 | 08:04 PM
Tatanko's Avatar
Bacon Lover
Mine is currently lowered down using washers since that hanger isn't in use at the moment due to a non-stock b-pipe. Eliminates a lot of the squeaking, vibrating, and rattling but if the pipe isn't secure it can still move and hit the exhaust tunnel.
Old May 19, 2006 | 08:08 PM
Mxrider52's Avatar
I support for what?
If you are lowered then it is the exhaust hitting the bracket. As soon as I dropped my car I started getting the sound..
Old May 19, 2006 | 09:11 PM
Apparition's Avatar
Ichiban King
well I keep coming back in here to see the deliberation, but I still dont see a flat out example of a fix. Its night time so I'm not going outside, but is that bracket vital to anything? If not just take if off? I imagine it is vital to something, but I mean if it is would new hangers or hose clamps come into play here?..
Old May 19, 2006 | 09:22 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
The sound like a few others said is your cat back banging on that bar. To fix it, replace all your exhaust bushings. Thoes rubber things that hold up the exhaust, you can see one in that pic. Just replace the bushings and you should be fine.
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Serotta33
Sep 17, 2015 12:14 PM
thenewguyy
Sep 12, 2015 11:12 AM
RealityCheck
Aug 5, 2015 06:18 AM
