Charging light??
Old May 19, 2006 | 05:33 AM
95mtlMAXSE's Avatar
shift_Puff
Charging light??
Hey guys...i have a little problem. My 99 came with a bad battery so i put in a new one(6yr warrenty and all), but now the charge and brake light pulsate simultaniously and even stay on together afeterwards. Even I rev up the motor it doesn't go away. Sometimes it happens and sometimes not. Can you guys shed some light on this issue. I have a 99% feeling it's the alternator, but i just want to make sure it's not something else.
As well, i searched for polyurathane bushing kits for the max and couldn't find one. I even used the search options, but didn't help much. Thanks
Old May 19, 2006 | 05:47 AM
clive's Avatar
100% chingon
Well of course it's the alternator! It's not charging.
To confirm this simply put a multimeter across the battery terminals. When the engine is running you should see at least 13.8 volts. If it is much less, you're not charging.
Old May 19, 2006 | 08:26 AM
95mtlMAXSE's Avatar
shift_Puff
i know about the multimeter reading, but i was just confused to why the brake light would flash with it. That was my concern...it's the first time i see that with the charge light at the same time
Old May 19, 2006 | 08:32 AM
Anii23's Avatar
My pathfinder would do the same thing every time the alternator was about to go.
Old May 19, 2006 | 08:59 AM
highoctane79's Avatar
Yeah its kind of weird to see both lights, like what do these have in common. but yes its usually the alternator.
Old May 19, 2006 | 10:24 AM
pmohr's Avatar
No more Maximas...
Yea, that's what Nissan does, brake/batt light to indicate an alternator malfunction. Have it tested at an auto parts place for free to make sure, but chances are high you'll just have to replace it.
Old May 19, 2006 | 10:49 AM
95mtlMAXSE's Avatar
shift_Puff
my frined is an electrical wiz...he'll test it...but i'll just buy another one at this rebuild place near our house(starters and alternators) and new belts. From there I should be fine. Thanks guys
Ohhh about the bushings...anyone know anything about it. I need to change mine and willing to buy some as of next week or so, but have no idea where to get some. Thanks
fastcarny
Oct 6, 2015 10:42 AM
rnb754
Sep 14, 2015 11:39 PM
Maxima30
Sep 7, 2015 06:13 PM
jfl330
Sep 4, 2015 01:44 PM
