5spd swap HELP!!!!
Old May 19, 2006 | 10:31 AM
Dysfunctional
5spd swap HELP!!!!
hey guys,
my friends got a 4th gen a 98 and we put a 95 ecu in did the whole swap, axels, clutch . everything is in and functioning, but now the car wont start
we double checked all the sensors and what not. anyone know how to help,
are there wiring diagrams that show me what to change over. thanks
-dys
EDIT< there is a clicking noise when we start put the key in the ignition
Old May 19, 2006 | 10:34 AM
pmohr's Avatar
No more Maximas...
Did you either ground the park/neutral sensor, or wire it up to a clutch switch?
Old May 19, 2006 | 10:35 AM
Dysfunctional
grounded it
should i wire it to the clutch switch
instead of running the wire to the clutch we just connected the 2 wires together
it cranks over, just wont run / turn over
Old May 19, 2006 | 10:41 AM
pmohr's Avatar
No more Maximas...
You don't have to wire to a clutch switch, I guess I worded that as an either/or, and not an 'either or nothing' question.
Have you checked if you're getting spark? Pull out a plug, connect it to the coil pack, and ground it to something. Crank, and see if it fires.
mtrai760's Avatar
'Trynna' is not a word
Why did you put a 95 ECU in a 98?
Old May 19, 2006 | 10:44 AM
WielkiWaac's Avatar
MaximaDriver
try to put 98 ecu and see if it works. because if car cranks there is nothing wrong with P/N switch
Old May 19, 2006 | 11:08 AM
Dysfunctional
no spark,
were going to see if we can get a ecu from a 96. btw the car is a 97 and we have a 95 tranny.
anyone in CT that wants to come to my house and see if ur ECU works
Old May 19, 2006 | 11:23 AM
mtrai760's Avatar
Put your stock ECU back in. An auto will still run with the transmission removed as long as the park/nuetral switch is bypassed, you will just get a CEL for the tranny codes.
Old May 19, 2006 | 11:26 AM
Dysfunctional
really
okay, ill go put the auto one back in and if it runs we know its the ecu. thats a beautiful thing
ill brb in 30 mins
keep the help coming
Old May 19, 2006 | 11:28 AM
darklegend06's Avatar
isn't the 97-99 different from the 95-96? Cause first of all 95-96 have a o2 right after cat, while the 97-99 have the o2 in the b pipe. I don't know anything else but you might want to get a 5spd ECU from a 97-99. I'm not sure but that is my guess.
Old May 19, 2006 | 11:41 AM
Dysfunctional
my friend didnt research this to well so now we get to trouble shoot alittle bit.
anyone know if it has to be a 97 - 99 ecu for the 5spd?
Old May 19, 2006 | 11:46 AM
Nismo3112's Avatar
Custom User Title
Did you try the stock ECU yet?
did you try to put back the auto ecu?
Old May 19, 2006 | 11:52 AM
Dysfunctional
doing so now
Old May 19, 2006 | 12:04 PM
Stillen Maxima's Avatar
Pay to Play
Hopefully it will start with stock ecu!
Old May 19, 2006 | 12:08 PM
Dysfunctional
still no start with the stock ecu ... what did we miss?
Old May 19, 2006 | 12:26 PM
Dysfunctional
it cranks over, but it only sparks ocasionally ... what could we have missed?
(like once every rotaion) i dunno what to do , anyone got pics of what to do? maybe some pics of what to do next.
Old May 19, 2006 | 12:43 PM
mtrai760's Avatar
Did you put the timing ring on the new flywheel?
Old May 19, 2006 | 01:15 PM
Dysfunctional
timing ring?
wtf is a timing ring for the flywheel?
Old May 19, 2006 | 01:26 PM
WielkiWaac's Avatar
MaximaDriver
timing ring?
did you flywheel have that smaller gear on it??
Old May 19, 2006 | 01:32 PM
Kevlo911's Avatar
Kevlo for President
Lol, check ecu for codes, you prob are throwing one(crankphase/timing ring).
Old May 19, 2006 | 02:13 PM
Dysfunctional
OH, THAT THING!!!
are we supposed to take it off of the AUTO flywheel?
or buy a new one for the 5spd one ...
i've never dont this auto - 5spd thingy-magig.
i dont remeber my 3rd gen having that ... is it supposed to?
oh deer, i think were a lil over our heads.
Old May 19, 2006 | 02:23 PM
mtrai760's Avatar
Yep, you must pull that ring and install it on the manual flywheel. Time to pull the tranny...
Old May 19, 2006 | 04:13 PM
Dysfunctional
is it the same thing from the auto to the manual? or is there 2 different plates, one for the auto and one for the manual?
oh well, here we go again
Old May 19, 2006 | 04:40 PM
Nismo3112's Avatar
Custom User Title
Correct me if i'm wrong, but don't manual flywheels ALREADY have this piece installed?
Old May 19, 2006 | 06:46 PM
tavarish's Avatar
fwd gone rwd cr00
I've done this EXACT swap, make sure you have the starter connected properly. If it just cranks, its the crank sensor, make sure it's plugged in and bolted down. It's easy to iss in the swap, and you won't start without it. You can run either ECU, your car will run the same.
Old May 19, 2006 | 06:57 PM
beats me I'm going to do the 5spd swap sometime soon hopefully so when the time comes I'm calling the people on CMC over to help me out.
Oh and good luck with the car, hope everything works out for you. Don't forget to post back and tell us if it worked or not.
Old May 20, 2006 | 06:14 AM
WielkiWaac's Avatar
MaximaDriver
why didnt you call mike jez (blackbirdvq)??
he has done more than 10 swaps - including mine
Old May 21, 2006 | 08:57 AM
Dysfunctional
i found out what the problem was, we have to line the flywheel up with some mark on the tranny, theres like a pin or something.
just wanted to say thanks for everyone helping us out. we'll prolly rip it this week
thanks alot everyone
Old May 21, 2006 | 03:56 PM
asperos28's Avatar
ahhh it wasnt it, i dunno wat is wrong with it but it wont start any more help please...
Old May 21, 2006 | 05:47 PM
Nismo3112's Avatar
Custom User Title
It HAS to be a sensor... namely the crank sensor that reads the teeth on the flywheel. You have any CEL codes?
Old May 21, 2006 | 06:26 PM
mforrest100's Avatar
OH, THAT THING!!!
I experienced the same exact symptoms because of this timing ring. The reason my flywheel didn't have it is because I took the flywheel from a friend of mines that replaced it with a Fidanza. He didn't know and neither did I that the timing ring had to be removed from the stock flywheel and put on the Fidanza. But Nismo3112 is right. If you didn't install an aftermarket flywheel, the timing ring will be on the stock one unless you bought it from a person that removed it from there car.
Mike
Old May 22, 2006 | 05:43 AM
asperos28's Avatar
can i get a timing ring from nissan? or where else could i get one?
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
