Engine Resonance
Old May 19, 2006 | 04:24 PM
LTU_max's Avatar
Engine Resonance
After using seafoam, a few days later my car started making kind of resonance sounds. It sounds like a high to medium high hum, with a little bit of grinding, but pretty mild. It does this only when it's very low RPM, usually idle. It happens on and off on certain days, usually the colder the worse it is. The engine temp also doesn't matter, the sound happens either cold or warm. Any ideas on what it can be? I've heard that people's spark plugs get some residue on them after the seafoam, but I don't think the spark plugs have much to do with such a sound. Any ideas?
Old May 19, 2006 | 05:26 PM
LTU_max's Avatar
Here's a clip of the noise on photobucket:
http://smg.photobucket.com/albums/v6...=Resonance.flv
Filegone (Better quality):
http://www.filegone.com/49h9
Old May 19, 2006 | 05:29 PM
Delvin's Avatar
Is everything tight on the intake piping? Is it idling rough?
Old May 19, 2006 | 05:34 PM
LTU_max's Avatar
Intake piping is pretty tight, idling sometimes rough. You can see what I mean in the vid ^^
Old May 19, 2006 | 05:37 PM
Delvin's Avatar
What I should have asked was do you feel anything when its making that sound? I heard it in the video and it sounds like the engine or exhaust is bearly hitting something its not supposed to and the feedback is going throughout the interior.
Old May 19, 2006 | 05:52 PM
LTU_max's Avatar
I can sometimes feel my accelerator pedal vibrate barely. But only sometimes, usually it's just the noise, can't feel any vibrations.
Old May 19, 2006 | 09:51 PM
darklegend06's Avatar
it seems more like something is loose. Very interesting. Sorry can't really help.
Also are you coming to the Nissan meet at busse woods this sunday?
Old May 19, 2006 | 11:39 PM
LTU_max's Avatar
Probably not What do you guys think could be loose? I'm pretty sure it's internal, since the seafoam is what caused it. Maybe too much carbon build up somewhere, causing the vibration? Maybe an oil change?
Old May 20, 2006 | 12:07 AM
jvelos3's Avatar
does your brake pedal vibrate...next time you hear this press your brake pedal...
I also hear a similar sound with my max...not as loud or as frequent...but I can feel vibration through my brake pedals a little on the gas but not as much. I have no idea what it is either.
Old May 20, 2006 | 11:42 AM
LTU_max's Avatar
Actually when I drove today, I didn't feel any vibrations. I have no idea what to do, since it can gradually get worse. Also, I added more seafoam (deep creep) into the IM when it was doing the noises, and the noises got louder - that was the video, after some more seafoam. So basically, the seafoam made it louder/worse, but the car drives just as great as it did before, maybe even a little bit better. 1st gear is now a monster, and can be going 20mph, floor it, then just hear tires spinning, then 2nd, and a nice big chirp. So I'm thinking maybe get an oil change? I need to change every 3,000 miles, and it has been 2,100 since the oil change. The noise is now more frequent after the seafoam as well...
shilov
Feb 19, 2024 09:40 PM
BkGreen97
Apr 2, 2016 05:47 AM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
Maxboy23
Sep 4, 2015 06:04 PM
