ignition system help
Old May 26, 2006 | 06:05 AM
blk96maxim's Avatar
ive always had a tricky ignition ..when u turn the key u have to hold it an extra split second for the car to start.. its been struggling lately to get it started..i have a feeling im gonna have to replace it.. what does something like this cost?? would like to have an idea before someone tries to rip me off..thanks
Old May 26, 2006 | 07:01 AM
pmohr's Avatar
No more Maximas...
You can replace the ignition switch, see if that solves the problem. Apparently it's a common problem for 4th gens...
Looks like it costs about $25, $30.
Old May 26, 2006 | 04:08 PM
blk96maxim's Avatar
is that easy to replace?? i dont know jack about working on cars?? do u have a good website or link that might walk me through changing out the ignition switch?? thanks
Old May 26, 2006 | 04:45 PM
MIXXMAX's Avatar
Changing the ignition switch is easy. Just remove the steering wheel "cowl" trim. It is held on with 4 screws. Use a long extended philips screwdriver. Once you have the trim off, you have access to the ignition switch. It is held on with two mounting screws. Unplug harness. Remove and replace with new one. Simple as that...your done.
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
