Just changed my spark plugs and DAMN!!
Old Jun 8, 2010 | 05:12 AM
  #41
cashoit's Avatar
check your MAF harness. Might wanna replace it. Test MAF and IACV per FSM too.
Old Jun 8, 2010 | 05:28 AM
  #42
bob-lee's Avatar
Originally Posted by Dexter
The plugs I had in (BOSCH quadfires) were all burned up and ashy with only 6 months in they probably woudn't have lasted longer than a month had I not pulled them out thats how bad they were, I threw them away before it occured to me to take pictures , but I put NGK platinums in and started it up...DAAAAAAAAAMMMMMMNNNNNN the difference in power is like night and day, the engine now has more power, and accelerates quicker, DRIVING the MAX has been made enjoyable again!
I recommend putting NGK platinums to anyone with a MAX if you wanna bring out it's full power.
P.S.: F*CK YOU BOSCH YOUR SPARKPLUGS SUCK
hey i just wanted to know if you experienced any pinging with the old plugs that you had in there.......................
Old Jun 8, 2010 | 07:41 PM
  #43
dj99gxe's Avatar
Hey bob-lee - No pinging, just purchased the car it had 85K. I wanted to give it a tune up. Plugs - Fuel filter - Oil Change - Air filter - Got some error codes misfire changed out a few coils with used ones - new Knock Sensor - cleaned my IACV , Throttle body , Sea foamed intake and Gas Tank. Still I'm experiencing erratic idle only when it warms up though. Don't know what it might be it seems it could be a bad connection some where maybe on the MAF or the plug to it or ????. All injectors are clicking equal no abnormal sounds from one to the other. Any Suggestions would be appreciated. Thanks
Old Jun 9, 2010 | 02:24 AM
  #44
BronxSleeperMax187's Avatar
I'll pretend I didin't notice that your asking him about A post from 2006
Old Jun 9, 2010 | 02:25 AM
  #45
Hes not talking to you OMG it gets better
Old Jun 9, 2010 | 05:36 AM
  #46
cashoit's Avatar
U didnt mention u cleaned MAF. more than likely its the MAF or the MAF harness. Check voltages for MAF per FSM. Clean it with MAF cleaner. I dont trust ebay MAFs no matter what anyone say. Get one from autozone, if u need to replace.
SInce its so easy, check impedance on CPS and IACV too. Clean the ground points on the intake manifold for the CKPS and the ground point near the coolant overfill as well.
Old Jun 12, 2010 | 06:58 AM
  #47
SiathLinux's Avatar
Must we flame the new guy?
Old Jun 12, 2010 | 11:07 AM
  #48
defiance's Avatar
Yeah guys bosch is mostly for BMW volkswagen and mercedes as far as spark plugs go.
I cant really complain about there other parts in nissans such as o2 sensors.
Old Jun 12, 2010 | 11:09 AM
  #49
stamar's Avatar
bosch is also the oem for dodge.
Old Jun 12, 2010 | 10:45 PM
  #50
defiance's Avatar
really ? oem for all chrysler vehicles was champion back in the early 90's...
Old Jun 18, 2010 | 07:22 PM
  #51
theWalkinator's Avatar
Crap, I just bought 6 Bosch platinum non-capping plugs, should I return them and get NKG ones?
Old Jun 18, 2010 | 07:34 PM
  #52
stamar's Avatar
for my 89 van it was bosch. dodges come with bosch injectors bosch ignition etc....bosch fuel puimp. I know i replaced all that crap. it says bosch and chrysler right on it.
but its true champion is the oem of the trucks. ram truck champion spark plug yes.
Actually it says ngk is the oem of some dodges. chrysler uses a few different ones.
Old Jun 19, 2010 | 08:43 AM
  #53
stamar's Avatar
ya some dodge cars or trucks use ngk plugs as the oem. Some use bosch and some use champion. I just verified it.
champion makes good plugs for what it matters
Old Jun 19, 2010 | 11:07 AM
  #54
philly96maxima's Avatar
Bosch 4001 Plugs...installed 6 months ago...runs great...any opinions on these plugs??...about 8000 miles so far & running fine & FlieS!....
had original NGK's up to 210k miles.....
Old Jun 19, 2010 | 11:14 AM
  #55
Trini Boom's Avatar
Well if you don't have any issues with them just stick to it. You even said yourself the original NGK's lasted you 210K miles. Let's see if the bosch will make it that far.
Old Jun 19, 2010 | 11:23 AM
  #56
..yes yes,,I know the NGK's are the deal....just inquiring if any info on this particular plug..thee 4001's..........I tried pBosch platinums in a Mazda 626 years ago...pinged like mad and went back to the NGks in that also....but this time around,,,after I did the EGR cleanout and replace back fuel injectors,,,running like a rocket now,,,,I would have put the ngk's back,,but the part s place,,,out of stock.....just looking for some other real experience on this #4001 plug...
mvm062
Nov 30, 2020 09:00 AM
knight_yyz
Nov 6, 2015 02:34 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
