Fuse under hood 7.5AMP "ALT. S" question
Old May 29, 2006 | 08:18 PM
HarrisH's Avatar
This fuse is under the hood in the rectangular box on the right hand side of the battery. It is labeled "ALT. S" and is a 7.5A fuse. Yesterday I realized this fuse was broken. Some of you may remember my threads about my voltage being high, mid to high 14s often 15.0 well the voltage certainly came down and started settling around 14.6-14.7V after replacing the fuse today, I realized now my voltage is mid 13's, I was just wondering if this fuse had any correlation with the alternator, and or the charging system.
Old May 30, 2006 | 07:41 AM
HarrisH's Avatar
Does anyone know???
Old May 30, 2006 | 07:46 AM
thomas.989's Avatar
If you have not gotten your alternator replaced, call nissan and ask them if your car had the alternator recall done. The diode in the alternator are faluty and can cause a fire. My alternator was smoking on and off and I got it changed for free from the dealer. Try this first.
Old May 30, 2006 | 10:54 AM
HarrisH's Avatar
Well I'm sure the alternator is fine, it was just purchased from the dealer months ago. So I'm assuming it doesn't have a bad diode. I'm just really curious as to what that fuse does and why the voltage would drop nearly 1 volt.
Old May 30, 2006 | 10:58 AM
Kevlo911's Avatar
Kevlo for President
Yes, I had to replace mine when my alt died.
Old May 30, 2006 | 11:21 AM
HarrisH's Avatar
Do you know specifically what it stands for or what it does?
Old May 30, 2006 | 11:22 AM
HarrisH's Avatar
So am I good with the 13.3-13.7 voltage?
Old May 30, 2006 | 12:38 PM
HarrisH's Avatar
Kevlo do you know?
Old May 30, 2006 | 12:43 PM
Kevlo911's Avatar
Kevlo for President
Oh my bad haha.
Mine blew and tripped the batt and brake light. It blew when I was connecting the connector on the alternator that recharges the batt(2pin). So it does have something to do with the voltage regulation and charging. And you are fine with 13.x volts. Get the charging system tested at autozone since it puts a load on the system and checks it.
Old May 30, 2006 | 12:54 PM
HarrisH's Avatar
Np man , are you talking about the rectangular connector, it's the only connector on the alternator, I believe it's a 3 prong connector, but the alternator only has 2 prongs. Yeah my voltage is consistent, no fluctuations or pulsations but nevertheless I will get it test today, keep in mind I'm running a system, HIDs, etc.
Old May 30, 2006 | 01:05 PM
Kevlo911's Avatar
Kevlo for President
Turn off the audio and does the voltage get closer to 14.x?
And yes, it is a 3pin connector but 2pins are used.
Old May 30, 2006 | 01:18 PM
HarrisH's Avatar
No infact the audio or headlights have very little effect on the output, the voltage will drop a hair when rolling up the windows or when the fans kick on which is normal but they shoot right back up to the mid 13's, it's not reaching towards the 14s at all. What do you think? Maybe an issue? It's an essentially brand new OEM Nissan alty from a dealership. Only a few months old.
Old May 30, 2006 | 01:19 PM
HarrisH's Avatar
Also my buddies max with a non-oem reman'd. alty charges in the low to mid 13s as well.
Old May 30, 2006 | 01:22 PM
Kevlo911's Avatar
Kevlo for President
I wouldn't worry about it. But it would be nice if it were closer to 14ish. Go to Autozone and see what there machine reports on it.
Old May 30, 2006 | 08:14 PM
HarrisH's Avatar
I went to autozone it was between 13.8-13.9 directly at the battery. The amps however were not going above 4.0 the tech at AutoZone said the amps should be 60 I don't know if that's true or not though. But pulling out the fuse the "ALT. S" fuse did raise the volts back up to the upper 14's. What do you think about the amps though?
Old May 31, 2006 | 09:51 AM
HarrisH's Avatar
Kevlo what do you think about the amps?
Old May 31, 2006 | 10:01 AM
Kevlo911's Avatar
Kevlo for President
4amps? or 40?
If it's 4 amps I highly doubt you can run your car lol.
Old May 31, 2006 | 10:46 AM
HarrisH's Avatar
It was between 3.0 and 4.0. I'm not sure if he was testing it correctly then? Are you familiar with the Autozone machines?
Old May 31, 2006 | 11:01 AM
Kevlo911's Avatar
Kevlo for President
Yeah mine always said much higher numbers on their machines. Did they make you hold the revs at 2000?
Old May 31, 2006 | 11:30 AM
HarrisH's Avatar
Yes they did lol, the voltage I'm not worried about, the amps I am however what do you think about the amps?
Old May 31, 2006 | 01:21 PM
clive's Avatar
100% chingon
OH DOG not another battery voltage thread
The so-called 'Tech' is an idiot.
4 amps charge is reasonable when the car is running. Without lights or anything else you're only powering the ignition and the fuel pump, basically.
60 amps? Put 60A into the battery for just a little while and watch the thing explode. Battery terminal volts on charge should be 13.8 nominal, depends on brand and age.
Old May 31, 2006 | 01:23 PM
Kevlo911's Avatar
Kevlo for President
Are you kidding me? You know the alternator pushes over 100amps around 1500-2500... High output alternators can push 100amps at idle.
Old Jun 1, 2006 | 06:43 AM
HarrisH's Avatar
Should I just get a voltmeter and test the amps? I don't think they're low though I mean the car runs JUST fine I'm just not clear as to why they're machine would register a number so low.
Old Jun 1, 2006 | 07:06 AM
Kevlo911's Avatar
Kevlo for President
Yeah I don't see how the car runs fine. I wouldnt worry about it. As along as the car is charging under a load and stuff. Maybe the Autozone machine was messed up.
Old Jun 1, 2006 | 07:22 AM
HarrisH's Avatar
Yeah 4 amps seems way to low for the car to be running lol, are voltage and amperage related? Is there a formula in which I would be able to obtain the actual amps in correlation with the volts?
Old Jun 1, 2006 | 11:02 AM
whitegold's Avatar
V = I*R
Ohms Law.
Old Jun 2, 2006 | 12:59 PM
HarrisH's Avatar
So guys here's the RULE! If you think you're having charging problems, PLEASE CHECK YOUR FUSE! The past 3 years I've been here I've read a plethora of threads that are related to charging, overcharing, undercharging problems/issues/concerns and not ONCE was this stupid fuse mentioned.
Old Nov 13, 2018 | 08:34 AM
Fromanfro's Avatar
Two pin harness
The white wire with red trader stripe goes to the battery through the alt s (s for sensor) fuse. It sends the battery voltage to the alternator to sense the charge condition of the battery. A low voltage at the battery tells the alternator to increase the charging voltage . When the fuse is blown there is no voltage, which of course is low voltage caus ing the alternator to max out, 15.2v for my aap Reman, which triggered my brake and battery lights to flash due to this condition. The other pin, black and yellow wire goes to the idiot light.
Old Nov 14, 2018 | 04:53 AM
max ride 41's Avatar
umm, 12 y/o thread bump here.......
Old Nov 14, 2018 | 01:19 PM
Fromanfro's Avatar
Huh?
I have no idea what that means. But when I was looking up help on my problem this thread came up and it helps me. I added some things that I also found out that we're not in this thread that may help somebody else.
Old Nov 15, 2018 | 09:12 AM
Fakie J Farkerton's Avatar
A useful necropost? These are rare!!!!
Old Nov 15, 2018 | 10:20 AM
DennisMik's Avatar
I'll comment on this in another 12 years if I'm still alive.
Old Nov 15, 2018 | 11:29 AM
sb001's Avatar
Well since the OP of this thread never got his question answered 12 years ago...
helpthisguy
Apr 6, 2013 12:54 AM
sirposted
Nov 28, 2012 02:04 PM
tfunkadelic
Oct 9, 2012 10:46 AM
dlf531
Mar 11, 2012 01:44 PM
maxtuner96
Oct 10, 2004 07:37 AM
