Converting Clearance lights into blinkers
Does anyone know where i can find a write up for converting my clearance lights into blinkers and my current blinkers into lights that come on with the headlights?
just swap the bulbs and sockets. You will need to enlarge some of the openings because they are shaped differently. I have the 95/96 corner wiring (dual filaments) in my corners and swaped the bumper blinkers to running lights.
Snip the power wires to the blinker and clearance lights. Splice the wire for the blinker into the wire going to the clearance light. Then splice the clearance wire into the snipped blinker wire. You may need to add a few pieces of wire to make up the distance. Done.
its really simple. the blinkers off the clearance housings are REALLLLLY bright at night and light up the whole sides of the car like a foglight. I've already made my bumper lights alternate blinking, and am soon going to have the clearance light as another blinker. can't have a light idly on with no function.
I have swapped my lights around so many times.
This is stock marker light (194), blinker wired same as marker light(1156), and clearance light wired for both parking and blinker(1157):
This is stock marker light(194), clearance light on bright(1157), and blinker wired for both parking and blinker(1157):
Here is marker light (194)and blinker unhooked(1156), clearance light wired for both parking and blinker(1157):
This is marker light (194)and blinker(1156) both wired together as a blinker, stock clearance light (1157) off:
Check out page 2 of my home page for various shots of the lights. If you see one you really like post it and Ill tell you how to do it.
Is this a mod or is this a factory feature. For clarification purposes we are talking about the light next to the headlight correct. I've seen this light shine brightly when you signal kinda like a Caddy. My 96 doesn't do it, is there something I've missed. I've checked my fuses traced and inspected the wires for breaks or loose connections all good so what's up?
Excuse my ignorance Captain Piccard is there something im missing? I know its a completely Noob ? Im not wanting the light to blink like a signal i want it to shine brighter when i signal and back to normal. with signal off. NOT LOOKING FOR ALWAYS BRIGHT MOD.
http://forums.maxima.org/4th-generat...on-maxima.html
See if it's in there..
Iirc, the I30 has that feature..might look into that as well.
lowpost99
05-16-2021 11:18 AM
fastcarny
10-06-2015 10:42 AM
-ReLLiK-
09-08-2015 12:02 PM
Maxima30
09-07-2015 06:13 PM
