HELP!!! 00VI install
Old Jun 4, 2006 | 01:26 PM
aznsap's Avatar
i just installed an 00vi, but i tried to start up and my idle rpms kept bouncing up and down. up to ~2.5k and back down, bouncing in about 1-2 second increments. then i thought maybe my throttle cable was too tight so i went out to pull on it and my rpms climbed to about 4k and i shut if off. any ideas?
i used the 5th gen TB and plugged in just one iacv plug like SDot did in this thread:
http://forums.maxima.org/showthread.php?t=463248
and the other 2 plugs going into the 4th gen iacv previously were left unplugged. guys help please i need my car tomorrow. thanks.
Old Jun 4, 2006 | 02:22 PM
aznsap's Avatar
okay, so i started it up again. rpms start @ 1500, then slowly climb. and then after a few seconds, it starts fluctuating between 1500 and 2000 rpm.
the thing is, i took it for a drive, and this rpm jumping happens at idle AND while i'm driving, which is a pain.
with that said, is it still an iacv problem? i used a 4th gen lower and the gaskets (the lower/upper gasket looks to be real thick piece of rubber), but it looked like the 5th gen upper has it's own thin rubber around the holes. i wonder if i may have a leak there and maybe i should just remove the 4th gen rubber gasket?
MaxLife17
Jun 27, 2019 01:37 PM
t6378tp
Sep 29, 2018 04:27 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
