Clearence Light Rewire 'How-2' is up
Old Jun 19, 2001 | 11:06 AM
NickStam's Avatar
Courtesy of me
Please let me know if you have any info that I should add in.
Old Jun 19, 2001 | 11:22 AM
GaMax97GLE's Avatar
Good job.
Originally posted by NickStam
Courtesy of me
As always, your how-to's are well done with good quality pics. Keep it up. Now I just have to get off my @ss and actually do it. Thanks.
Old Jun 19, 2001 | 01:20 PM
NickStam's Avatar
Re: Good job.
Ya, getting rid of them dim was nice!
Old Jun 19, 2001 | 01:33 PM
WaarrEagle's Avatar
Is there any downside to this? Any problems with overheating or anything? Anyone had any problems?
Old Jun 19, 2001 | 10:33 PM
bkomatsu's Avatar
Mine worked fine, but when I turned on my car and then the lights it blew a fuse. I replaced the blown 7.5A fuse witha 15A fuse and it worked. Hopefully this will fix the problem. Anyone have any suggestions? They look really "Dope" though!!
Old Jun 20, 2001 | 05:05 PM
WaarrEagle's Avatar
But wasn't the 7.5A fuse there for a reason in the first place? Is upgrading it to 15A good for the wires and all? Or does it make a difference?
Old Jun 20, 2001 | 06:08 PM
NickStam's Avatar
Ya, maybe I should mention something about that. Mine have not blown but I have heard that a couple people's have blown. I'm not sure that upping the fuse is good. I would rather have it blow, and just replace the fuse.
Old Jun 20, 2001 | 06:13 PM
bkomatsu's Avatar
Why is not good to up the fuse? It only blows when I turn my car and with the 15A fuse it hasn't blown yet. It made sense to me because rewiring them is upping the watts. I don't know maybe I am wrong. But it has worked so far.
Old Jun 20, 2001 | 07:22 PM
GaMax97GLE's Avatar
Just finished the rewire...
...and it looks gooood. It was hella easy too. Thanks again.
Old Jun 20, 2001 | 09:21 PM
WaarrEagle's Avatar
I am no electrician but the wiring in that section of the car was originally designed to take a certain amount of wattage. Upping the fuse allows more wattage through which might cause some problems with the wiring or who knows what else. Like I said, I am no electrician so if someone who really knows about this kind of stuff could respond, I would appreciate it.
Old Jun 20, 2001 | 10:36 PM
pawn's Avatar
i to did this mod tonight......it was very simple, but the only thing was the first one was a snap, i turned the lights on to see if i had done it right and tada it worked, i did the second one exactly the same, but it would not turn on....then i thought maybe the bulb was burnt out so i swapped em' nope no such luck,....so i went to put the one back in the other side and now none of em' worked...so i decided to say f u c k it and i put it all back together so i could drive home and finish it tomorrow.....so i backed out of my shop, and walked around my car and no tail lights....so i new the problem....to make this long story short, i eventually ended up putting a 15 amp under the hood, and a 30 in the dash......will i have probs w/this????
Old Jun 20, 2001 | 10:51 PM
gtr_rider's Avatar
192.168.1.1
now all you have to do is slap that front speaker how 2 on there, you know the deal with props.
Old Jun 21, 2001 | 05:58 AM
NickStam's Avatar
I don't understand why some people blow fuses. I have never had a problem in the 1 yr I've had this done.
Old Jun 22, 2001 | 12:55 AM
pawn's Avatar
i had a big prob w/this mod
tonight on my way home this saturn tried to race me...while in the process of stomping a mudhole in its @$$ i blew the tail light fuse, i replaced started the car backed up turned the lights on...and i noticed smoke rollin out by the passenger side light......i imedialty turned everything off......it fried the friggin wires....HOW do i go about fixing the wires....so i have to buy new ones or what....cuz i don't have any tail lights now, cuz if i put the fuse back in it will start on fire.....so until someone helps me.....no driving at night......this sucks......
Old Jun 22, 2001 | 05:33 AM
GaMax97GLE's Avatar
Mine is still fine
No problems yet and I don't anticipate any, hehe. I didn't realize how bright those lights got until last night while actually driving. They shine a big spot on the ground on each side of the regular headlights. This isn't illegal is it? Not like I care anyway...
Old Jun 22, 2001 | 09:10 AM
JacksMax's Avatar
Naaaahhh! Just pull all your sub 20s and replace with 20s! Problem solved! (trolling for a post from Daniel)
Jack
Old Jun 22, 2001 | 02:13 PM
pawn's Avatar
so does anyone know how to go about fixing the wires that fried.....also does anyone know wtf caused this?????
Old Jun 22, 2001 | 03:18 PM
bkomatsu's Avatar
I would venture to say it was a short in the wire somewhere. Trace the wire and look for some sort of kink or split in it. Also look at the connector and make sure you soldered it good. Thats about as far as I can help ya.
Good Luck
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
