Best way to get this out. . . maybe fire?
Old Jun 10, 2006 | 08:58 PM
MDeezy's Avatar
I know the pic gives away how I could get it out but I dont that (forgot the name) and even if I went to pick one up I dont have a solid enough table to bolt it down to.
I thought I saw a pic where some one flame broiled it out, can I pick up some fire and burn it out pretty easy?
I would have bought a new one had I remembered to add it to my list and I wont have time to buy one before monday (work) or tuesday (going out of town).
Thanks.
Old Jun 10, 2006 | 09:16 PM
f550maranello2's Avatar
bro trust me the blow torche is ur best friend with that... burn i off
Old Jun 10, 2006 | 09:28 PM
MDeezy's Avatar
I thought so, I'll pick up some fire tommorow at home depot. Hopefully its relatively cheap.
Old Jun 10, 2006 | 09:31 PM
werd man.... its 12$ for the torch burn as much of that crap as possible then MAKE SURE you remove the metal sleve that is insid that tube... do it with a blade from a hack saw.. just be careful not to gouge the surface of the metal...
Old Jun 10, 2006 | 09:53 PM
MDeezy's Avatar
what metal sleeve
Old Jun 10, 2006 | 10:16 PM
chillin014's Avatar
oh a vice. damn dude, you dont have a sturdy table? bolt it to the dang porch or side of yur house.
wat exactly are you doin there?
Old Jun 10, 2006 | 10:20 PM
MDeezy's Avatar
i'll see whats cheaper. if the fire is cheaper i'll go with that. now that i think about it, there might be a place i could bolt the vice too, i hoopee its strong enough....
Old Jun 11, 2006 | 04:42 AM
dgeesaman's Avatar
Maintenance Monster
Fire works, not much else does. Make sure if you're buying a torch to get a MAPP gas torch instead of propane. Propane is fine for sweating a few copper pipes, and cheaper, but for car work you want the extra heat.
Old Jun 11, 2006 | 10:08 AM
MDeezy's Avatar
**Update:**
The propane torch was good for just about nothing. It heated up the rubber but didnt do much besides make everything very hot.
Eventually With the head a few other tricks I got the piece out but I only got it out of the rubber, so the extra ring thing is still on it, preventing me from putting it in the new control arm. Anyone have any ideas on how to get that off? Its stubborn as everything and not sure how to get it out.
Now that I think about it I should have taken the route shown in my first post, that way I would have un-screwed it from inside the control arm. Fire even if hot enough was the wrong way to go, I would have just melted the rubber but left it still inside that metal cylinder.
daamn
Old Jun 11, 2006 | 10:21 AM
JwaxMax99's Avatar
I had this exact problem. To get the ring off I took my grinder, ground out a groove in the ring just flush with the silver arm, then peeled the ring off.
Old Jun 11, 2006 | 08:57 PM
konak85's Avatar
try MAPP gas. its more intense than propane
Old Jun 11, 2006 | 09:19 PM
aussie983's Avatar
This is for the 3rd gens, but im sure it will apply here too:
http://mattblehm.com/faq/control_arm...placement.html
TKHanson
Nov 24, 2018 01:39 AM
mpbclutch33
Dec 26, 2015 11:11 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
