HELP!!! I was Cleaning out TB and now my car won't start!
Old Jun 13, 2006 | 11:31 AM
Dexter's Avatar
I cleaned out the TB and I put everything back together, tightened the clamp on TB connected the 2 big hoses and the small one and connected both sensors, now my car won't start I can hear the fuel pump turn on then shut off, I think I might have drowned the engine because I opened the butterfly plate a couple of times
so do I let it sit there for a while and let it undrown itself or is there anything I have to do to undrown it?
Old Jun 13, 2006 | 11:42 AM
joew's Avatar
car won't start after cleaning TB has never happened to me. did you plug back the fuel pump fuse correctly?
Old Jun 13, 2006 | 12:40 PM
Dexter's Avatar
I didn't remove the fuel pump fuse, it didn't say anything about removing the fuel pump fuse. just unhooked the battery
Old Jun 13, 2006 | 01:13 PM
Capitone's Avatar
Does your car even try to start? I mean does the engine roll over at all? I know that after a good cleaning, initial start up may be a little difficult, but once you get it going, all that muck you cleaned out will exit out the back via ya muffler.
Old Jun 13, 2006 | 01:29 PM
bkea's Avatar
If you really hosed down the throttle plate, you may have flooded the engine. Prop the plate open for a while or just wait.
Also check and make sure the MAF sensor is plugged in. You might have unplugged it while removing the intake.
Old Jun 13, 2006 | 01:54 PM
Dexter's Avatar
ok, i figured it out. I held the accelerator all the way down then started it up. car starts right up now
Old Jun 13, 2006 | 02:22 PM
Dexter's Avatar
wait so I had to hold the butterfly plate open THEN spray it in?! if so then I only sprayed the plate not what was after it...
I guess I'll have to do it again, but how am I supposed to reach in there or will the carb cleaner take care of that?
Old Jun 13, 2006 | 03:04 PM
the_3d_man's Avatar
dude just get a rag and reach in there. you might get a little dirty and if you're not carefull you might sratch yourself on the butterfly.... but thats the only way to clean it out without taking it all off...
Old Jun 13, 2006 | 08:04 PM
Dexter's Avatar
ok done, cleaned it and started it up
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
Balkins
Aug 12, 2015 06:39 AM
