Might need coil packs...so sellers help me out, see if you agree with me
Old Jun 17, 2006 | 08:24 PM
Saddles's Avatar
Car runs fine normally as long as its getting gas, if i floor the gas, it will sputter and lose momentum (this happens at all speeds and in all gears). If I let off the gas it picks back up. If the clutch is in, such as at a stop light ect car may die. This seems to be made worse when it is raining outside. Car throws CEL's 15long 7short and 7long 6short which are undefined. So do you guys think it's coil packs? And if so, who has a set they want to get rid of, this will get moved to the classified section if you all agree with my diagnosis. Thanks for your help. Forgot to mention the idle is rough. Drops and idles high, then low...levels out...back down..up again, ect.
Old Jun 18, 2006 | 09:07 AM
99grnmaxgxe's Avatar
Since you didn't get an accurate code reading, I'd go to Autozone to get the codes pulled and see what you get, if it's the mulitple misfire, time for some new coil packs.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
MichMaxFan
Sep 30, 2015 09:18 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
