replacing the radiator support
Old Jun 26, 2006 | 06:58 AM
97BlackSEGold's Avatar
I was in an accident a while back, it wasnt that bad, the radiator support, hood latch, and headlights were pushed in by the bumper of a jeep that got cut off and slammed on the brakes. Anyways, i tried to pull out the bent radiator support myself with a winch and everything lines up pretty good but not perfect and its starting to bother me so i decided that i'm gonna put in a new radiator support and start from scratch on the front end. My question is....Is the radiator support welded onto the frame or bolted? I dont want to start ripping apart my front end only to realize that it is wlded on. thanks
Old Jun 26, 2006 | 07:08 AM
MaximaSE96's Avatar
Maxima Owner
I am prety sure its welded
Old Jun 26, 2006 | 07:56 AM
nismology's Avatar
It's welded...
Old Jun 26, 2006 | 08:01 AM
tavarish's Avatar
fwd gone rwd cr00
i'd remove the bolts, and use a dremel or sawzall to remove the spot welds, bolt the new one in, and have it welded.
Old Jun 26, 2006 | 08:04 AM
pmohr's Avatar
No more Maximas...
Don't you need some sort of rack to keep the frame aligned when taking it out? I recall having read somewhere that it was necessary to have some sort of special equipment when replacing this.
Old Jun 26, 2006 | 08:12 AM
tavarish's Avatar
fwd gone rwd cr00
i'd just use regular jack stands. the engine would be out of the car when i do this, so not much weight would be on the frame anyway.
Old Jun 26, 2006 | 08:17 AM
nismology's Avatar
Agreed. A body shop should do this.
Old Jun 26, 2006 | 08:23 AM
damn that sucks, i was hoping this wasnt going to cost too much, if its welded on im not even going to mess with it....
CRizz
41
Jun 7, 2021 05:42 AM
mvm062
Nov 30, 2020 09:00 AM
maxinout93
Oct 27, 2015 01:29 PM
Balkins
Aug 12, 2015 06:39 AM
