squeaking in left front... ideas?
Good evening boys and happy 4th. I have a squeaking coming from the left front of my car. It's got to be suspension related because I hear it all the time if the road isn't perfectly smooth. It's loud enough for me to hear with the windows up and A/C on. The suspension is 1 year old and are Illuminas and Tein H-Techs. I also replaced strut bearings and all appropriate parts when doing the suspension install. I put the car up on my ramps and siliconed all suspension parts to get no satisfaction from this squeak. I also can make it squeak with the car parked and standing on the outside and moving the car from side to side. Any ideas of parts to grease or whatever would be appreciated. Thanks again
Remove and check the front sway bar bushings. I'm talking about the ones that surround the bar and bolt in near the steering rack.
Xlr8r has a 'front end rebuild' thread going on that has pics of these bushings when the get rubbed thru.
Dave
Dave
http://www.jatan.net/tsbs/056820.pdf read this, if its none of thos maby your springs are really rusted over?
I'm having the same problem with squeaking. I just recently installed Tein H-techs and KYB AGX's, which seem to have heightened the problem. I have about 140k miles on the car, and i'm sure some of the bushings must be shot by now.
99SEL4ME, let me know if you make any progress with the noise!
Sway bars bushings are in the back, right?
the front suspensions is pretty simple, maybe time for some exploratory surgery 5 bolts and a Clip get the strut/spring off, if the springs get really rusty they will squeak like a **** yo
Both front and rear passenger side spring/strut assemblies are squeaking on my car, and I only put the new suspension on 2 weeks ago...there's not even any dirt on them let alone any rust. And I'd bet there's not much rust, if any, on 99SEL4ME's suspension either.
Yeah, I'm going to see my Nissan Tech on Saturday and he is going to find the squeak and fix it!! Before it drives me to drink!! I will post the solution when it's found.
Thanks for all your input. BTW, my car has 134k on it but suspension, springs and bearings are all new 1 year ago.
well...it's definitely the swaybar endlinks causing the squeak in my car. the bushing is almost completely gone. If i pushed up and down on the hood it would squeak just from that. I soaked it with some wd40 and it went away for a good while.
Might wanna try that to see if that is the problem. Good luck with it man.
Thanks. I know its loud from the outside, because people walking on the sidewalk, mainly teenagers, will turn their heads before I pass them! And it's not my POS stock Bose stereo turning their heads either.....lol. New sway bar bushings..... here I come!!!
END LINKS or SWAYBAR LINKS will squeek mostly, not the sway bar bushings. They are usually quiet. The Swaybar Links are metal on metal and when the grease inside washes away they squeek. This part is basically a metal ball inside a metalic part that is tight enough to hold it to keep the ball from disconnecting. And for some reason they are not greasable. They should be because they would last forever.
The ball is sealed on the end of the top threaded bolt---
Dave
Originally Posted by 99SEL4ME
Nice!! Good visual!! A+++ my friend. I see, I see said the blind man as he pissed in the wind, it's all coming back to me now.... Are these expensive to replace? Thanks man!!
Also it is a good idea to get the sway bar bushings while you're at it. $10?
I think you can find them online for about $30 - $40
At the dealer all the stuff will run you $70-$80.
Heres the thread where someone bought them cheap somewhere...
http://forums.maxima.org/showthread....ight=end+links
Originally Posted by dgeesaman
I've had the opposite experience. The swaybar bushings under the brackets can wear thru and allow metal-metal contact between the bar and bracket. You won't see it until you remove the bushing and see the cut.
Dave
Dave
Okay, here's the verdict. Today, I got replaced both sway bar links and the squeak is gone!! Also, I got 2 oxygen sensors, bank one and bank two with Nissan sensors. Parts and labor $500. Does that sound like too much to anyone? each o2 sensor was $140. from Nissan. And the sway bar links were $100. Sound a little on the high side to me.....
I can see the o2 sensors being high from Nissan, but 2 swaybar links for $100 ? And they're not Nissan. I think my " friend" made a mistake. Nissan links aren't even that much, they're like $20. I thought my a$$ hurt a little today.....
i went to the dealer 2 days ago and the links and bushings were $48 per side...but I would say that is high since they aren't Nissan. O2 sensors vary depending on the car, so I would guess they are right on.
...atleast they're not O2 sensors for a Honda Prelude....$300 a piece from Napa!!!
REDinLV
Aug 15, 2024 12:30 AM
maxima297
Sep 30, 2015 03:32 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
