new taillights
Old Jul 4, 2006 | 04:36 PM
jos's Avatar
jos
new taillights question
Just put in Altezza Euro taillights. Plugged everything in. The side light is a clear bulb - on the stock light it shows up under a red reflector. On the Altezza Euro's it appears white. What gives? Is this legal? OR do I need to buy a red bulb?
Old Jul 4, 2006 | 04:56 PM
Hexon's Avatar
Can you post a picture? I am sort of lost with what you are saying.
One of the bulbs is suposed to be white because of it being a back up light. Turn signals are supposed to be amber or red, and brakes are supposed to be red.
Old Jul 4, 2006 | 04:58 PM
jaep0913's Avatar
Old Jul 4, 2006 | 05:15 PM
DukeDuke's Avatar
You need to go buy a red or amber bulb. The stock lights had the red reflector over it so it turned it red... your tail lights should have come with the correct lights you need for the install. But you need a red or amber bulb. It is worthless if it is clear. Now if it is a reverse light that is one thing.
Old Jul 4, 2006 | 05:34 PM
jos's Avatar
jos
Sorry,no pics. There is a backup light (white). The light I am talking about wraps around the side. DukeDuke seems to make sense about the whole thing.
Old Jul 4, 2006 | 07:31 PM
Cdg2125's Avatar
Duke makes sense because it's true. The stock bulb is clear...just like most stock bulbs in the car. The red is a reflector so you need a red bulb in that spot.
Old Jul 5, 2006 | 03:40 PM
IlyaK's Avatar
The Golden One
Jos...off-topic. Wanted to say what's up to a fellow South-Albany resident. I'm just up 9W/87 (exit 22).
Old Jul 17, 2006 | 08:00 AM
99max78210's Avatar
I put clears with LED lights. The only weird thing was when I tried to put LED turnsignas in the fronts they wouldnt work....
Old Jul 17, 2006 | 08:07 AM
Caracicatriz's Avatar
What was that?
Altezzas FTL
Old Jul 17, 2006 | 11:29 AM
bigpulve+'s Avatar
One question...........Why are you putting ricer lights on a beloved Maxima? Unless your going to do the skyline mod?
Old Jul 17, 2006 | 02:18 PM
'96 B-rad's Avatar
I just changed all my lights to amber. Had clears in front and red/clears in back with all white bulbs. Just went to the auto place and bought some bulbs and put them in. Took like 5 mins to change the 4 bulbs. And no its not legal to have clear blinker lights.
Old Jul 17, 2006 | 02:27 PM
D-Bo's Avatar
Droppin logs
You are being punished by a higher power for trying to put Altezzas on your car.
When I bought mine and took them off, I did see that the corner running light had been changed to yellow. I simply pulled the bulb and taped up the socket and left it in the trunk cavity when I installed my red/clears. You can do that or swap it to a yellow bulb.
Old Jul 26, 2006 | 12:05 PM
TunerMaxima3000's Avatar
OK lets set this straight, is the bulb in question a tailight bulb that would be on constant when lights are on, or simply a turn signal? if it's a turn signal you dont need to change it, the law is that you may have NO rearward facing white lights running constant, they have to be intermittent or reverse lights.
Old Jul 26, 2006 | 12:09 PM
Supermax95's Avatar
Thats it YOUR state, In california the rear turn signal has to be orange or red....
Old Jul 26, 2006 | 12:29 PM
JPMax's Avatar
What's next!?..
The lights he's talking about are on the outer tailights in the lower outside corners. They are on constantly when the lights are on. They're just rear side marker lights and don't have anything to do with the turn signals or the backup lights.
Get some red bulbs to put there. #194 I think.
Old Jul 29, 2006 | 06:48 AM
erty67's Avatar
Decal Specialist
I know which light you are talking about. As DukeDuke said, get a red bulb. I suggest getting 194 Red LEDs. They will stay red. My Red 194 bulbs ended up white again.
Old Jul 29, 2006 | 08:17 AM
udienow's Avatar
You dont have to get red bulbs there.... if anything you can totally unplug it and it dont do anything, if it is indeed the light im thinking about. I just got red/clears and now have the stock bulb there so they appear that ugly yellow white.
Krazzespiinz
Sep 13, 2015 07:10 AM
JoshG
Sep 5, 2015 10:10 PM
220k+ A32
Aug 17, 2015 03:57 PM
dauntlessmax
Aug 5, 2015 10:29 AM
maximaxgtr
Mar 25, 2001 04:01 PM
