what is the best way to get the stock brake line off
Old Jul 6, 2006 | 08:42 AM
mb1's Avatar
mb1
strugled with it untill i partially rounded the bolt on the hard line.
Old Jul 6, 2006 | 09:34 AM
cardana24's Avatar
Blown
Let me start out by saying I have never done this, so take it as you will. But wouldn't vise grips work? Or will the pinch/bend the line?
Old Jul 6, 2006 | 09:55 AM
scubasteve's Avatar
OHHH YEA SCISSOR!!!!
VG's will work but then the fitting should NOT be reused. The fittings are soft metal, i believe brass, and will get damaged. So basically if you use vice gribs you will most likely have to
a) buy a new breakline assembly or
b) replace the fitting which requires cutting the break line, put on a new fitting and re-flare the end with a brake line flare. this will shorten the breakline, making life difficult.
what you need is a set of fitting wrenches, hey are shaped differently to hug all edges. A set at advance auto is bout 14 bux
Old Jul 6, 2006 | 10:20 AM
MaximaSE96's Avatar
Maxima Owner
well from doing this i can tell u....on old fittings flare wrenches suck and round out the fitting and visegrips dont damageas much as u think....
Old Jul 6, 2006 | 03:59 PM
njmaxseltd's Avatar
Using the correct tools would have prevented that.
You need a flare wrench to work on brake lines.
Old Jul 10, 2006 | 08:19 AM
mb1's Avatar
mb1
so i use the flare wrench to hold the hard line, and what do i use to loosen the rubber line?
Old Jul 10, 2006 | 09:14 AM
RedfoxXx's Avatar
buy a haynes, PS I wouldent mess with vice grips mine if you paid me
Old Jul 10, 2006 | 04:38 PM
mb1's Avatar
mb1
i have a repair manual but i dont htink it says anything usefull on that topic
Old Jul 10, 2006 | 11:00 PM
Sin's Avatar
Sin
Buy another fitting. Cut off the hardline just behind the rounded fitting. Slip on a new fitting. Use a flare tool to reflare the hardline. Done and done. Besides the hardline being about an inch shorter, it's good as new. At the worst, you may have to use a zip tie, or some metal wire to secure the now slightly shorter hardline to the mounting tab.
9aj9
Apr 5, 2020 12:11 AM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 16, 2015 07:20 PM
bbsitum
Sep 11, 2015 04:55 PM
crazyespn
Sep 3, 2015 01:30 PM
