Surging
Old Jun 21, 2001 | 01:17 PM
Torrie
I have a 1997 maxima. My engine surges all the time even when in park. I've done a complete tune up on this car. My cavalier did the same thing and it was a throttle sensor. I was wondering would anyone know what's going on.
Old Jun 21, 2001 | 02:39 PM
shumax's Avatar
test it
Get a shop manul--hanes will be fine. Pull and codes from the computer. Then go out and test the TPS and the MAF sensor. I bet you will find your problem there. Hopefully it's just the TPS as that's cheaper to replace. Last thought....when you did the tune up you might have knocked a vaccum line off. I did that to mine and the cruise wouldn't work anymore and it idled a bit rough. I went back and found it after an hour of searching and tracing vaccum lines right off of the Throttle body---happened when changing the fuel filter!
Good Luck--
You might want to give a 'shout out' to Daniel B. Martin. He is the expert at tracking these things down.
Old Jun 21, 2001 | 03:57 PM
Daniel B. Martin's Avatar
Re: test it
Good Luck--
I agree with everything Shumax said. I'll add one suggestion. Carefully inspect the flexible black plastic air duct which conveys filtered air from the air cleaner housing to the throttle body. A crack in that duct might cause, or contribute to, your surging symptom.
RWCreative
Sep 21, 2015 11:01 AM
mtrai760
Aug 20, 2002 08:42 PM
SeBlackMax97
Aug 17, 2002 05:07 PM
MadMax92SE
Apr 3, 2002 06:42 AM
