Drive axle seal
Old Jul 9, 2006 | 07:10 PM
cr00klyn718's Avatar
Drive axle seal
How do I remove the axle seal from the housing? I need to replace the seal b/c it is leaking tranny oil. Is their any tools that is used to remove this? I can't get this thing out.
Thanks in advance.
Old Jul 10, 2006 | 04:59 AM
Chickan's Avatar
check the Haynes manual, supposedly has a good write up on it.
Also, did you check your axle for movement? It can move in and out (pulling and pushing), but if it moves up/down left/right then you most likely have bearing damage, and simply replacing the seal will not fix your problem. It will help for a short time (1 month or so), and then it will be leaking again. Only true fix is proper rebuild of the tranny with properly shimmed bearings.
Granted, if you have an automatic, this problem doesn't apply to you.
Also, when you put the new seal in, don't push it in to far, as there is nothing there to prevent it from going in too far.
Old Jul 10, 2006 | 06:09 AM
yepp auto.
Old Jul 10, 2006 | 06:53 AM
Chickan's Avatar
in that case, I don't know. I have my manual at home, not here though.
You might check the FSM: http://phatg20.net/media/FSM/Nissan/...995_Maxima.rar If you go to their site, you can find others, but it is mildy hard to navigate.
Old Jul 10, 2006 | 08:06 AM
f550maranello2's Avatar
its not THAT bad.... just make sure that you dont scratch the mating surface.. i used a crow bar to get it out....
Old Jul 10, 2006 | 11:28 AM
NAPhi_Shift's Avatar
i hope its just the seal. :-\
PH98I30
29
Feb 10, 2025 12:03 PM
boomerbrian
Oct 31, 2018 10:25 AM
captchaos
Mar 15, 2016 12:18 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
boomerbrian
Sep 4, 2015 08:25 AM
