Starting Problem, back fire, etc... :'(
Old Jul 11, 2006 | 05:57 PM
oVeRdOsE's Avatar
Hi,
I already post my problem, but i got no ansews.
Well, Ive just change my tranny ( 5speeds), car works great before the removal, but now I have serious problems.
When I'm starting, it take about 6 seconds before the engine starts. I have back fire in my exhaust. BUT, when the engine runs, everything's fine. Except not burn gas smell.
I got engine's code myself, maybe its the problem?
#1 : EGR system Hi/low flow (03 04)
#2 : knock sensor (03 02)
Old Jul 11, 2006 | 05:59 PM
tavarish's Avatar
fwd gone rwd cr00
grounding is your problem. run a 10 gauge wie from one of the bolt on the tranny (bottom 12mm), and one of the starter bolts, and you should be golden. The same thing happened to me.
Old Jul 11, 2006 | 06:04 PM
oVeRdOsE's Avatar
Ive just clean up all my oem groun, AND Ive install a grounding kit 8.
One wire goes on the starter directly, one on the throttle, one on the inhectors and one on the frame near the driver side shock.
Thanks a lot
Old Jul 11, 2006 | 06:06 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
wouldnt it be nice if the maxima just said "please ground my transmission" lol all well maybe by the 10th gen maxima.....
Old Jul 11, 2006 | 06:18 PM
oVeRdOsE's Avatar
Ive already 2 clean ground on my transmission
Old Jul 12, 2006 | 12:38 PM
oVeRdOsE's Avatar
any clues?
Old Jul 12, 2006 | 07:09 PM
crazy97's Avatar
Check out this thread-
http://forums.maxima.org/showthread.php?t=452286
Old Jul 12, 2006 | 07:56 PM
oVeRdOsE's Avatar
Originally Posted by crazy97
mmm, seems right, even if ive clean all my oem ground.
You maybe right, I have only 2 ground on my tranny, tommorrow ill try to put 2 more and I let you know.
Thanks a lot!
Old Jul 12, 2006 | 08:04 PM
oVeRdOsE's Avatar
What about my EGR code? Big deal or not?
My code comes ALWAYS when Im shifting my 3 at 60 mph 6000 rpm. This problem wasnt there before the swap.
Old Jul 14, 2006 | 06:29 PM
oVeRdOsE's Avatar
THANKS to tavarish and crazy97!!!!!!!
Problem fixed!
I guess 1 ground was not enought, it take me 4! (alsmost same places than crazy97).
Start like a new!
Thanks to everybody
Old Jul 14, 2006 | 06:42 PM
JwaxMax99's Avatar
I would also fix the EGR problem.
Old Jul 14, 2006 | 11:06 PM
crazy97's Avatar
Problem fixed!
Start like a new!
Thanks to everybody
Amazing!!!
Old Jul 16, 2006 | 10:13 AM
timandleighsa's Avatar
I have pulled the motor out removed timing housing, to replace the orings. Now a few days later car has same problem listed above. Going to try a ground. But what about the guy from texas that stated nissan had wiring issues in the 97-98 maxima. I own both years. the 97 is the one having issues. any help would be great. first time poster.
Old Jul 16, 2006 | 10:50 AM
gassian's Avatar
Hey tavarish/overdose i have the same since i changed my tranny (auto)..i grounded my tranny from the battery and it worked fine but still does every morning kinda..
so did you guys grounded from the tranny to the starter??
please i need this fixed big time bothering me BIG time
thanks
Old Jul 16, 2006 | 01:36 PM
crazy97's Avatar
thanks
The most important ground would be the starter to the negitve cable.
Old Jul 16, 2006 | 02:14 PM
gassian's Avatar
okay thanks alot crazy97 i will try to do that sometime this week or maybe today.. hope it works...
Old Jul 16, 2006 | 04:08 PM
it must not be that big of a concern for my daughter, told her about the grounding issue. still has not showed up for me to fix. It must be a good ground when installed from factory, then when we pulled motor away from trans, it needsto have a good clean ground. thank you for youre replys. Hay good luck to you gassian also.
Old Jul 16, 2006 | 05:46 PM
crazy97's Avatar
Make sure to only ground one of these bolts on the starter-
Old Jul 16, 2006 | 08:16 PM
gassian's Avatar
i did it to one those bolts with 12 gauge wire straight from the negative terminal..and still i have the same issue...
kinda pissed
Old Jul 26, 2006 | 01:05 PM
TunerMaxima3000's Avatar
kinda pissed
that would be cause 12 gauge wire isnt big enough, electricity takes the path of least resistance, the ground from the battery to the block has 4 or 8 gauge wire, you NEED to go bigger to get any kind of improvement
Old Jul 27, 2006 | 10:11 AM
maximakun's Avatar
I have a similar problem as well. Sorry, don't want to hi-jack anybody's thread but this problem has been pretty annoying. Two misfires,knock sensor,
a realllly annoying starting problem (takes majority of the time 3-7 starts to start!), and I have 2 o2 sensors out which I'm sure contributes to my 220-230a tank mpg. I replaced my MAF also because it was out. My main two problems I'm worried about is the two misfires and the starting problem. Oh, right, this is a 'new' motor because old one was messed up. So I'm guessing whoever has done the swap sucked *** but if it is just grounding for the starting issue then where to ground? I'm new to the maxforums. And for my misfires, I've replaced the plugs to NGK-Rs but I was wondering about the coil packs? What voltage range should they be in? Also, my ECU is gay cuz the lil screw where you do the CEL procedure is broken because I can go either direction forever. Any advice would be much appreciated. Thanks for everybody's time. Sorry about the hi-jacking, can't post new threads yet.
Old Jul 27, 2006 | 06:23 PM
jayboydog's Avatar
starter sounds weak, now no start.
over the past 10 days i noticed the car was not strating right up. yesterday after having driven a few miles and returned home. the engine would not start again. (i do not hear any sound of fuel pump) but the starter motor sounds weak. headlights are strong so i feel battery is good. when i turn key to start, the starter sounds weak...as if the car battery was not sending good voltage. i put the key in the on position, and touched a screwdriver across the two bolts on the 'thingy' attached to the starter motor! the thingy sounded good (kind of high pitch) but the starter motor did not seem to get a good turn. anyone have an idea of what the problem is? thx.
95 max. 61,000 miles. original starter!
maxinout93
Aug 20, 2015 02:17 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
kirkhilles
Aug 8, 2015 10:53 AM
Gsantos79
Aug 8, 2015 07:41 AM
