HID installing problem so frustratedd argh =[
so i got my helios hid kit from Group Deals. It arrived yesterday, and installed this morning. I connected all the wires together and mounted the ballasts and igniters. After turning on the headlight, it wouldnt turn on. So i turned it on and off couple times, and then i see my foglight bulbs exploding. So i got scared and pulled everything back out and put on my stock headlights. My friend said i need a "bigger or better battery". I really have no idea, and im so frustrated right now, because i was so excited for brighter lights and spent $300 on it... please give me any advice
Originally Posted by happyricefob
make sure you are pluggin in the 12v and ground correctly. and check to make sure your 12v is plugged in at low beam, not high beam (common problem)
Answer taking from Jstutter conversion thread
The low beam wire is green with a yellow tracer for the driver’s side and blue with a black tracer for the passenger’s side. The ground for both sides is black with white dots.
last wire is high beam
Lakersallday24
03-20-2024 11:22 AM
jomax14
08-12-2015 11:49 AM
kirkhilles
08-08-2015 10:53 AM
