Groaning noise from brakes.
Old Jul 15, 2006 | 10:28 AM
gx2nds4's Avatar
When my car starts moving after stopping using brakes theres a groaning noise. I think it's my e-brake because i normally dont use it but yesterday i pulled it because i was getting under my car to check something. Besides http://www.motorvate.ca/mvp.php/303 are there any other fixes/outlines i should be looking at? Or perhaps other outlooks on the problem?
Old Jul 15, 2006 | 12:23 PM
nearthisbridge's Avatar
Front or rear? I'm assuming rear since you mentioned the e-brake...check out this TSB. I have the same issue occasionally.
Old Jul 15, 2006 | 12:43 PM
aznsap's Avatar
if it's the rear, your calipers could be seized.... and your pads could be worn all the way down and grinding into the rotors. if that WERE the case, you'd need new calipers/rotors/pads.
Old Jul 15, 2006 | 01:12 PM
gx2nds4's Avatar
it is the e-brake. and it is according to that bulletin but what i'm wondering is am i able to release it from under the car. Its not worn down since i dont touch the e-brake (i read about this issue before) but I used it when i got under the car since i didnt have ramps and was just using my driveway.
Old Jul 15, 2006 | 01:18 PM
Hexon's Avatar
It sould like a common issue I see with a lot of cars. Mine does it when I am completely stoped then I let my brakes off a little bit and it groans. My moms 05 maxima does it too, as well as our suburban.
Old Jul 15, 2006 | 01:32 PM
1996blackmax's Avatar
Brake noise can also be attributed to the kind of pads you are using, as well as improper break in.
When I was using Hawk HPS pads I would sometimes get some groaning from them. This was even after following the proper breaking in procedure.
Old Jul 15, 2006 | 02:24 PM
gx2nds4's Avatar
i "fixed" it. Played around with my e-brake until it stopped.
Old Jul 15, 2006 | 02:43 PM
nart86
what exactly did you do?
Old Jul 15, 2006 | 03:02 PM
gx2nds4's Avatar
pulled it up released. drove in drive reverse. pulled it up released it pulled up dont hold button, push button pull up and release. i dont know just fiddle with it hahah.
Quote:
Originally Posted by keleko
last time i had something like that happen, i did this:
put ebrake on, drive forward a foot or less, take it off, drive in reverse about 3ft
that seemed to make it release and i didn't have any issues after that
ymmv
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
