Starting issue
Old Jul 17, 2006 | 04:58 AM
CreativeDesignz's Avatar
Starting issue
Well for about the past year or so i have been having starting issues. Its mainly before the car is warmed up. The car will crank, start, stumble, then stall. it almost sound like the gears in the starter are grinding. but as soon as the car is warmed up or has only been sitting for 2 or so hours of no driving it starts up no problem. I replaced the starter and it was fine for about a month and then it started doing it every once in a while, and now its almost every morning. anyone have any ideas? plugs were just changed, all schedueled maintence has been done on the car im extremely **** about my ride and i just dont want to get stuck one day. possibly just need to reground the starter?
Old Jul 17, 2006 | 04:23 PM
to the top, anyone?
Old Jul 17, 2006 | 04:52 PM
Kevlo911's Avatar
Kevlo for President
Engine coolant temperature sensor maybe.
Old Jul 17, 2006 | 05:14 PM
Brent_Cunniff's Avatar
check if the plus are correctly in their designated spots
Old Jul 17, 2006 | 05:22 PM
Kevlo911's Avatar
Kevlo for President
What?
Old Jul 17, 2006 | 05:24 PM
JwaxMax99's Avatar
Exactly what I was thinking...
Old Jul 17, 2006 | 09:23 PM
Jellyfishian's Avatar
Difficult is NOT impossible!
I had a similar problem, just yesterday I cleaned my throttle body and not only did my problem go away, but the car idles so smooth! It only took me an hour and $4...
here was my post:
http://forums.maxima.org/showthread.php?t=481604
Old Jul 18, 2006 | 04:51 AM
crazy97's Avatar
A simple and cheap thing to try is to run a ground from the starter mounting bolt to the negitive cable and see what happens. This has helped a ton of people..
Old Jul 18, 2006 | 07:15 AM
^ yea thats what i was thinkin, tb has been cleaned, car basically has had a full tune up and the problem presists. if it was coolant temp sensor wouldnt the heat not get hot? and does anyone know what guage wire i should use?
Old Jul 18, 2006 | 10:48 AM
i30ds's Avatar
Armed and Dangerous
Could be fuel pump or fpr.
Old Jul 18, 2006 | 10:11 PM
Max96-97's Avatar
I have the same problem a while back. Cleaning the TB and replacing the ECT sensor solved it. My 96 Max also stumbled to stall occasionally while I almost slow to stop in front of stop sign or traffic light. After I replaced the ECTS ($12), the problem went away. I guess a bad sensor sends ECU a wrong signal that indicates something is wrong (coolant temperature too high?); the stalling/stumbling may be the ECU at work in response to the ECTS signal.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
