Whining noise under acceleration
Old Jul 17, 2006 | 08:51 AM
99max78210's Avatar
I've had my maxima to a transmission shop over a pretty pronounced whining sound that comes under moderate to heavy throttle in 1-3rd gears. I also hear the noise (but much less) when breaking. The transmission shop said its not the transmission which I do believe but the noise still is very suspect and the car didnt always do it. Is there some other part in the drivetrain that could make such a loud whine under load?
Old Jul 17, 2006 | 08:59 AM
Dan's Avatar
Dan
No Longer Owns a Maxima
Are you manual or auto?
Old Jul 17, 2006 | 09:04 AM
lefty
I had it due to my alternator. Once changed, all was fine.
Old Jul 17, 2006 | 09:08 AM
99max78210's Avatar
Its a manual tranny. The whining noise is extremely loud in the interior. It overtakes the sound of the motor which is why im concerned. The sound does not appear unless the car is in motion. Its not tied to rpms.
Old Jul 17, 2006 | 09:12 AM
Dan's Avatar
Dan
does the noise go away when you put in the clutch?
Old Jul 17, 2006 | 09:18 AM
99max78210's Avatar
it will because load is taken off the engine/drivetrain. The noise gets higher in pitch as the speed goes up until its too high to hear in 3rd gear. The same noise can be heard going lower in pitch under moderate breaking. The noise is much less pronounced in breaking.
Old Jul 17, 2006 | 09:55 AM
scubasteve's Avatar
OHHH YEA SCISSOR!!!!
exactly what i was thinking
Old Jul 17, 2006 | 10:01 AM
95mtlMAXSE's Avatar
shift_Puff
i have it also, only on first gear....like if the whine turns with the motor, i change to 2nd and all gone...i hope it's not the tranny
Old Jul 17, 2006 | 10:06 AM
Gismo-T's Avatar
B!tch We Got a Problem
Have the same whinning noise, but went away for a few months & came back yesterday! It ended up being the alternator. So, have your alternator checked out!
Old Jul 17, 2006 | 10:10 AM
99max78210's Avatar
I had a transmission guy look at it and he told me it was not transmission related. He said if the transmission was making that kind of noise, gears would be coming through the case. He thought it was in the engine compartment somewhere. If I thought the alternator would cure the problem, I would replace it in a heartbeat. I assume a whine coming from an alternator would sound the same at the same rpm. I bet you have it in 2nd gear as well (if its the same problem I have). I thought it was only in first until I listened really carefully. Its much higher pitched but still there. It gets too high pitched to hear around 50 in 3rd. Sometimes the whine oscilates from loud to soft and other times its just a constant loud noise.
Old Jul 17, 2006 | 10:38 AM
scubasteve's Avatar
not neccesarily (spelling)
Old Jul 17, 2006 | 02:25 PM
96blkonblkse's Avatar
didnt sound liek this did it
http://videos.streetfire.net/search/...793bb055ca.htm
made that video awhile back, tranny blew about 2 weeks later.
Old Jul 17, 2006 | 05:14 PM
99se5speed's Avatar
SHIFT_up
Could it be the TOB?
Old Jul 17, 2006 | 05:58 PM
dgeesaman's Avatar
Maintenance Monster
Although I haven't heard your car's noise, it is possible for a functioning tranny to be whining and loud. It just takes a few chipped gears. However, it doesn't come from nowhere, and tranny gear whine usually only happens when torque is going in one direction. So gear noise will either happen on coast down with the clutch engaged, or on acceleration, but not both.
Definitely check out the alternator. You might try removing the belt, starting the car, and running it for a few minutes to see if that stops the noise.
Old Jul 17, 2006 | 06:05 PM
prince_starbai's Avatar
I'd say the alternator as well..happened to me when it was on it's way out.
Old Jul 17, 2006 | 06:11 PM
grandmastr's Avatar
I have the same problem, I got a tube and put it right on the alt. and it was defainlty it. I am going to try change it tomorrow. I ordered a rebuilt from autzone online for 120 dollars with lifetime warranty. Does anyone have some tips doing the alternator?
Should i go from underneath it or try it from above?
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
uttadms31
Sep 30, 2015 05:24 AM
