O2 Sensors - OE or Universal??
Old Jul 17, 2006 | 12:57 PM
aih98max's Avatar
scoobystoned...
i need new O2 sensors for my 98. Can i just get universal ones and wire them in myself? is it pretty easy? also, do i need an O2 socket? and what brand should i get? i was thinkin Bosch.
Old Jul 17, 2006 | 12:58 PM
Kevlo911's Avatar
Kevlo for President
It will only be 3-4 wires so I would get universal. You will save about 20bucks and that is almost a 1/2tank of gas.
Rent an o2 sensor socket from Autozone for free. I would go with the cheap Walker brand, I have yet to read anything bad about them.
Old Jul 17, 2006 | 01:10 PM
CRiME's Avatar
oem ftw!
i got bosch universals for about 25.00 on ebay. they wire in with no problems. definitely get universal. the socket sucked for me, the only way to remove the sensor was w/ an open end wrench. socket was useless. but i do have the stock y-pipe, that could be why the socket was a no go; less working space.
Old Jul 17, 2006 | 03:01 PM
aih98max's Avatar
scoobystoned...
so i can change them with just an open end wrench??? i dont need the socket? thanks guys
Old Jul 19, 2006 | 09:33 AM
matrix11229's Avatar
Bosch Universal $27.95 shipped. I bought two front sensors from this guy. They are brand new and work perfectly, and the shipping was fast too. Many other members bought those sensors and that's why I decided to buy them too.They are exactly like the original ones that I removed. You just have to splice the wires of the new sensor and to cut off your old sensor from the harness and connect the new sensor to the harness together using the attached plastic connectors (the wires have the same color scheme - 2 white and 1 black) and then you heat the connector with a lighter in order to seal it and press on it with a rag while it's still hot - this way the rubber will be sealed perfectly.
You will be done in 20 minutes.
Yes you can use an open end wrench.
http://cgi.ebay.com/ebaymotors/NEW-B...mZ180008898757
There are 6 sensors left
Old Jul 19, 2006 | 12:34 PM
maximus_96's Avatar
how many are there for a 96? some reason i keep thinking of 4...
Old Jul 19, 2006 | 01:04 PM
aih98max's Avatar
scoobystoned...
thanks man, ur a cool newbie who knows what he is talking about
Old Jul 20, 2006 | 07:07 AM
maximus_96's Avatar
i went ahead and bought 3. from the pic at courtesy parts, looks like there are 2 in front and 1 in rear. the rear one is located at different spots depending on year...hope i was right.
Old Jul 20, 2006 | 10:08 AM
CRiME's Avatar
oem ftw!
there is one in the rear, but it's different to the two front sensors (at least that's how it is on my '95, pretty sure that this applies to the 96+ too). If you can, try to cancel your order for the third sensor before it's too late.
Old Jul 20, 2006 | 10:36 AM
maximus_96's Avatar
oh crap, thanks for the info. so the two fronts are the same for sure?
Old Jul 20, 2006 | 10:39 AM
CRiME's Avatar
oem ftw!
yeah, the two fronts are exactly the same thing. the only one that's different is the rear sensor. i've been having a hard time finding the rear sensor for my 1995; i was only able to find the fronts (which i ordered from that same link that you ordered from). that seller ships very quickly, and the sensors are brand new, and as advertised.
Old Jul 20, 2006 | 04:03 PM
96blkmaxgle's Avatar
Hi Matrix,
The same guys is setting NGK OEM sensors. The picture shows 2 black and 1 white wires while the sensor actually has (as you pointed out) 2 while and 1 black wire. I sent him an email to make sure this is the right sensor (thinking may be he posted a wrong picture by mistake)? No answer from them yet and it's been three weeks now.
Do you happen to know anything about it? Can you advise?
http://cgi.ebay.com/ebaymotors/ws/eB...DME:B:AAQ:US:1
You help is appreciated. Thanks man !!!!
Old Jul 20, 2006 | 04:23 PM
CRiME's Avatar
oem ftw!
Originally Posted by 96blkmaxgle
Hi Matrix,
I'm willing to bet that that photo is just a generic one. It lists 1995-2003, so you have nothing to worry about. That seller is very good as far as listing things accurately & shipping out the right product. If you need front sensors, Those will work.
Old Jul 20, 2006 | 06:26 PM
Thanks 2pb. Appreciate your reply. I will order it then. Thanks again.
Old Jul 22, 2006 | 05:31 PM
Hi Matrix,
This Ngk will work , but I trust Bosch so I spent $5 more and bought it.
Old Jul 22, 2006 | 08:48 PM
Sy0p's Avatar
i thought about getting universal then i was like **** that im not the great wire splicer so i just went to oxygensensors.com and about 3 new 02 sensors jacked up my car and plugged em in and im all good to go. less of a headace.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
