wtf? Piston Slapping? crap... so now what?
The only 4.5 gen in da 956
Last night, while helping my girls best friend, with her car.. we turned on mine in order to jump start her Concord, my boy is a mechanic at Ford, and he noted that the motor was making a noise... "similar to piston slapping" he said it was not a good thing... at first he said if its cold... its ok if the engines starts like that... but if warms up and it still sounds the same, i have some issues... is there anything can do to fix this.. what could be the problem? Is it time to swap to a 3.5? Thanks
raul
raul
I'm gonna double check.. my boy is a domestic car kinda of guy and he's been working as a mechanic for about a yr now.. soo he still needs some time and experience..... that and i'm the only dude in the crew who rides in a import... so I guess... he's applying what he knows about domestic to the import... I kinda want him to help me.. cause its free help... but he doenst know much about the car.. the way I know.. so......
Raul
Raul
Originally Posted by TurTLe*
the tick could just be the injectors. nissans's injectors seem to tick slightly louder then most out there.
Originally Posted by Maxima880
As TurTLe said Maxima injectors make a soft clicking as they cycle open/closed - very fast tempo, (6 per revolution),. Easy to distinguish from a knock which is usually 1 per revolution. A knock is usually cam/valve related though it can be connecting rod big end failure. An automotive s***hoscope or a wood dowel can usually help determine if the noise is coming from one of the heads or lower in the block or the timing chain area. Someone tell me was piston slap is. Is it wrist pin failure?
i've only heard a couple sound clips online, but imo it sounds totally different than the faint ticking noise we all get from our injectors.
Even if it is, and it only occurs during startup it is harmless. For years and years, like from 85 - 98, GM made J-body cars and they ALL had severe piston slap when cold starting even when nearly new. Its something you can safely ignore unless it doesnt go away.
04-16-2020 05:15 AM
6spd4dsc
03-04-2016 05:19 PM
imported_Nismo_max
09-21-2015 07:24 PM
ballerchris510
09-11-2015 05:29 PM
