starting on 2nd gear
Old Jul 20, 2006 | 04:00 PM
WielkiWaac's Avatar
MaximaDriver
Hi.
My first gear is out, it jumps out when i want to move forward. So from complete stop i have to start at 2nd gear. Im just wondering for how long i can do that. Dont have a time take my car to shop.
How about clutch?? Will it die faster??
Old Jul 20, 2006 | 04:04 PM
NmexMAX's Avatar
dot dot dot ...
Some automatic vehicles actually have this as an 'option' in low traction situations.
If you don't have time to take the car to a shop, get rid of it because you don't have time to be a car owner.
Old Jul 20, 2006 | 04:08 PM
dgeesaman's Avatar
Maintenance Monster
It will last quite a while, if you're halfway good at using the clutch and you aren't starting on uphills. Bad drivers can burn up a clutch using 1st gear faster than a good driver starting in 2nd. But that's not saying too much.
Dave
Old Jul 21, 2006 | 10:20 AM
NAPhi_Shift's Avatar
if your really good, it shudnt make that much of a difference, the car has plenty of power in 2nd.
when it snows 1st gear is absolutely useless in my car... wayy to much power wayy to low
Old Jul 21, 2006 | 11:59 AM
gosha's Avatar
you can do it for as long as your 2nd is still operational... but once the 2nd is out - then you'll have to tow it to the shop... Since your 1st is out I would suggest to at least drain transmission and check oil for metal - more likely you have a magnetic plug - smaller pieces will be sticking to it and larger (like broken off gear tooths tips) will be in the oil.
sctludwig
Sep 1, 2022 01:32 PM
pjgreek
Sep 9, 2015 09:30 PM
slowlifer
Sep 8, 2015 05:53 AM
dcardello
Sep 3, 2015 11:44 PM
