So does my 99se cali-spec have no potential???
i've been reading alot here about how cali-spec's have a bunch of useless junk in the exhaust and that fed-spec's are so much tighter than cali-spec.
what potential does my 99 SE-L Cali-Spec MAXIMA have? or do I HAVE TO CONVERT TO FED before my maxi can enter dopeness?
It has about the same as any other 4th gen. JWT has a program now, there for it lacks nothing. Treat it like a 5th gen and get some real headers, get some sort of VI, and something to tune with. Youre set with just a few mods.
Idk why everyone keeps saying that there's a pre-cat in the headers. I have a 99 cali spec and yes i do have 2 cat's. One AFTER my headers before the y-pipe and one after the y-pipe between the rear exhaust. I'll be changing both of those along with the y-pipe...
Sticky: 4th gen FAQs (READ ME! PLEASE! READ ME!)
What are the year to year differences on 4th Gen (95-99) Maximas?
1999 -
On CA emission 99's Front pre-cat built into header, two extra oxygen sensors to monitor pre-cats (total of 4), Swirl valve in intake to improve emissions. Special aftermarket Y-pipe required and only 1 pre-cat can be removed.
basically, this left me w/ the understanding that the pre-cat built into the header cannot be removed, and that there is 2 pre-cats. Is this sticky wrong? I want to know because I want to 'maximize' my 'maxima' naw mean.
The sticky is correct. I'm just telling you what i have on my car. My mechanic showed me both of my precats. I told him i have one in my headers and asked him if it's difficult to change it. He said why would you change your headers when you pre-cat is sitting right after them...I was in total shock but i do have 2 pre cats which i can clearly see under my car.
There is a thread about converting the front mainfold to a fed spec. The car was dynoed with both the cali spec front pre cat and a y pipe, then the stillen up pipe was added with a fed spec front maninfold. There are very very minimal gains, and you do lose some mid range power. If you want to be cheap about the conversion buy the SS autochrome headers and y pipe.
I don't want to remove it and ph uck it up.
In a Cali spec car, by putting in a Cali spec y-pipe you eliminate the pre cat near the catalytic converter. You do not get rid of the pre cat that connects to the header.
picture of how the Cali Spec Y-pipe looks and the remaining precat.
http://forums.maxima.org/showthread.php?p=4436022
that's what I keep reading, sounds like a waste of time and money for not much gain.sounds like a good idea, what about that front pre-cat, leave it there?
just convert it i did it last weekend and no matter what the dyno says my *** says it was worth it....personally dynos dont mean much to me what matters is how fast it takes off when i punch it.....if i feel a difference it was worth it.....
im in the middle of my 5 speed swap right now....the lbs im shedding alone will be worth it.....
Originally Posted by DaEnigma
actually, thnx alot enigma, this thread was exactly what I was looking for. I just read the whole thing and don't have a single question left referring to this issue.
edit: did you get any pictures of this swap?
The headers and y will replace everything in front of the main cat (below the shifter). They are cheap as heck, and all you will need is an O2 simulator. IMO those SSAC headers are crap, but hey for a cali spec they will convert you to fed spec for cheap as dirt, add some bling, and give you a nice y pipe all at the same time. Check the 5th gen forum out for some good info on headers/fed conversions. All 00-01 are like a 99. Most of those guys just shell out the money for Cattmans or Hotshot headers. They are a far better design over the SSAC, but much more money.
yeah, seems to be working for alot of people.
for example i need a timing ring to finish my 5 spd swap so everythings on hold for the moment.....
beans??? ohhh been beaten to hell and back. so I see. Thnx for the link, seems to answer exactly what I was wondering.
sdotcarter
Sep 2, 2015 09:53 PM
