uhh WTF just happened? pulley flew off *pics*
Old Jul 22, 2006 | 09:31 AM
4x4Max's Avatar
I was accelerating from a parking lot, took it to about 4k in 1st, i heard some noise and it was like something was falling off my car, and it was....pulled over, and i find the pulley laying next to my car....wtf??
It seems like only a part of the pulley actually came off, the ring that the belt goes on to.
Time to upgrade to a UDP?
Can somebody tell me what happened, how i can fix it, where i can buy the part, and if i can do this at home.
Old Jul 22, 2006 | 09:37 AM
Kevlo911's Avatar
Kevlo for President
That's fckin crazy man. Looks like the crank pulley. So you can get a UDP if you want.
Old Jul 22, 2006 | 09:43 AM
bkmax96's Avatar
broke off harmonic balancer lol just get another aftermarket pulley it wil b alot cheaper then going to a dealer
Old Jul 22, 2006 | 09:52 AM
4x4Max's Avatar
Where can i get an aftermarket pulley? Motostorm? I need this FAST because my car is out of commision until i change this, and i have to have a car.
Old Jul 22, 2006 | 10:25 AM
d00df00d's Avatar
Old enuf to pick his own gears
Looks like the rubber ring disintegrated and the outer part of the pulley detached.
You don't need to get a UDP. Either grab an OEM pulley or just get an Unorthodox Racing Ultra Sc pulley, which is lighter than stock but has the stock diameter.
As far as the operation itself goes, the toughest part is getting the center bolt out and torquing it back to spec afterwards. If you have a good impact gun, you'll be fine.
I have an OEM pulley I could overnight to you on Monday if you PayPal me. PM me if you want it...
Old Jul 22, 2006 | 10:33 AM
97WhtSE's Avatar
go to motorstorm pm me if you want ill give you his # and you can go pick it up i dunno it might be an a long drive for you. Its only 45 mins from my house.
Old Jul 22, 2006 | 11:01 AM
matty's Avatar
How many miles on your motor ?? That is crazy stuff.
http://forums.maxima.org/showthread.php?t=483290
Old Jul 22, 2006 | 11:08 AM
4x4Max's Avatar
Thanks for the link.
My motor has 89k miles, so its nothing...i have a shorter belt because my A/C pulley is jammed, so i just have a shorter belt...im wondering if that had something to do with it?
Old Jul 22, 2006 | 11:12 AM
konak85's Avatar
you probably had the belt on too tight.
Old Jul 22, 2006 | 11:21 AM
njmaxseltd's Avatar
The rubber isolation ring will deteriorate(sp?) over time, especially if you use harsh chemicals to clean your enigne. My buddies 98 I30 did the same thing.
Old Jul 22, 2006 | 02:04 PM
Mr Willis's Avatar
But of course it did don't be rediculous. LOL, remember balkey from perfect strangers?
Old Jul 22, 2006 | 03:11 PM
Zack342's Avatar
Neat never seen that before.
Old Jul 22, 2006 | 08:38 PM
4x4Max's Avatar
Then maybe i should get a UDP because it looks to be just a solid peice? Anybody have any kind of troubles when using the Motostorm UDP? It seems to be the cheapest, and their shop is in my state so overnight shipping would probably be cheaper too...
Old Jul 22, 2006 | 08:52 PM
ThurzNite's Avatar
Mine's cracked too. I posted about it awhile back:
http://forums.maxima.org/showthread.php?t=370342
I'm worried now. Next oil change I'll inspect again. I've got 180k miles right now.
Jae
Old Jul 23, 2006 | 08:04 AM
nsnrider's Avatar
My friends Max had the same problem, at first he didn't realize it, every time he started his car, the accessory belt would shift towards the engine and rub against the engine parts. we lifted the car up and found the same problem; we changed it right away. good luck.
Old Jul 23, 2006 | 08:52 AM
Nismotic's Avatar
Always sunny in philly
I had the same problem. I also thought "did something just fall off of my car?"
OEM pulley should do it.
Old Jul 23, 2006 | 09:05 PM
4x4Max's Avatar
wow so it seems like im not the only one that this has happened to...can somebody answer my questions about the UDP? (any troubles with it)
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
Need help
23
Oct 2, 2015 08:56 AM
