Dashboard how to?
Old Jul 24, 2006 | 06:42 AM
KDog125's Avatar
Dashboard how to?
is there any post on how to take out the dashboard middle pannels b/c i need to take my cd player out but dunno how to do it...thanks
Old Jul 24, 2006 | 06:52 AM
95mtlMAXSE's Avatar
shift_Puff
you'll need a flat head screw driver(to pop out panels) and a star screwdriver for the screws. First remove the panel around the shifter console(if auto put on Neutral, it's easier), the remove the vents above the defroster switch by un clipping the botom first and pull outwards firmly, but gently. One screw on for the ashtray(left side) and 4 screws for the radio/climate/compartement box. They come out as one unit...then all u have to do is unscrew the radio form it and replace it. Hope it makes sense...or get the fsm
Old Jul 24, 2006 | 07:08 AM
scubasteve's Avatar
OHHH YEA SCISSOR!!!!
and to get the shifter panel up without risk damage/scratches i found the best way is too unhook the boot from the e-brake and pop it from underneath =]
Old Jul 24, 2006 | 07:13 AM
black_maxed95's Avatar
www.installdr.com
Old Jul 25, 2006 | 12:55 PM
Cdg2125's Avatar
Its actually a quick and simple process. Once the shifter trim is off you should be able to go right through it. Just look at it and you'll figure it out. Only hard part that I had was the vents. When I first popped them off the vent opened and all the plastic pieces came undo. I had to put them all back together so I could actually use the vent. Just go do it.
Old Jul 25, 2006 | 01:07 PM
nearthisbridge's Avatar
Just a tip, the clock/hazard assembly and vents come out as one piece and makes things even easier. There are two clips on the bottom of the clock/hazard piece, just stick a small flat-head screwdriver in and pop them out. Then pull down and out slightly on that assembly and they should both come out together.
Old Jul 26, 2006 | 10:49 AM
Cdg2125's Avatar
When I originally pulled out the clock/vent assembly is when it all came apart. I started using the flathead afterward to push on the top part. There's that other clip that holds the top part in. After I strted using the flathead up top I never had a problem again.
gavin68
Sep 18, 2021 12:36 PM
vingodine
45
May 21, 2016 12:46 PM
yat70458
Aug 3, 2015 01:16 PM
MyMaxima97
Oct 27, 2001 03:33 PM
ylun
Oct 4, 2001 04:15 PM
