Help newbie to choose a torque wrench
New to these fun DIY stuff. Decide to re-grease my starter pretty soon. In two months or so, I would clean TB, replace spark plugs/coil packs and KS.
A lot of bolts of the DIY works above need properly torqued. My question is, what size of torque wrench should I have? There are different head sizes and wrench length available on the market. How and what should I choose one (for all the works I mentioned above)?
TIA
TIA
I used a torque wrench for none of those, but if you do I'd get the 1/4" drive that measures in in-lb.
IMO it's most important when torquing fasteners that require 10+ ft-lb, since they are often under greater load. Smaller fasteners that hold the KS or intake together really just need to be snug, and not overtightened. Spark plugs are usually finger tight + 1/2 turn or something like that - if they're new that's just enough to partially crush the metal washer that comes on the plug. You might want to look up the plug tightening procedure yourself.
Dave
Dave
+1 on not really needing a torque wrench for those projects. you will need one if you're serious about working on your car, though, and i think that a half-inch drive that measures up to 200+ ft/lbs would be the best choice for you.
The only thing you need a torque wrench for are lug nuts and the bolts inside your engine, everything else just needs common sense. A torque wrench is a good thing to have, but you have to learn to not rely on it for everything. Lots of people will waste so much time looking up torque specs and setting their wrench to tighten things like strut tower bolts, or manifold bolts when you really can just do it by hand.
Ive replaced just about everything on my car (minus the motor) at one point and the ONLY thing I have ever used my torque wrench on are the lug nuts.
Originally Posted by grandmastr
I use the torque wrench when im gasket work on teh cars, like replacing the valve cover gaskets.
It's true that it's important to use common sense and you don't really "need" torque wrenches for a lot of tasks. I have torque wrenches but I don't always use them. But nothing wrong or bad comes from using it or relying on it in order to torque to spec.
I agree with southeast_first that a half-inch drive that measures up to 200+ ft/lbs would be the best choice, especially if you don't have a half-inch drive rachet or breaker bar. Maybe 150 ft/lbs one might suffice.
Originally Posted by hasei
Minimum. It's actually 174 according to FSM. Max is 231.
I'm not so worried. The cotter pin holds the king nut which prevents the nut from backing out. All good!
Jae
Hdnseek
09-09-2015 05:55 AM
carid
09-09-2015 05:06 AM
