Front Suspension Bushing Replacement/Upgrade
Old Jul 25, 2006 | 06:22 PM
Wheelie King's Avatar
I'm going to replace my front sway bar to control arm bushings because my originals are very worn. Has anybody used the Energy Suspension bushings? They're only $6.50 each compared to $8.50 or $23.50 for two different Moog bushings.
Has anybody used the Energy Suspension Front End Control Arm Bushing set? Is it worth $35?
Are there any other bushings I should plan to replace while I'm under there? Does anybody know of any good sets?
Old Jul 25, 2006 | 06:39 PM
crazy97's Avatar
I have energy suspension bushings on the way, should be here tommorrow. I ordered the swaybar to frame bushings along with the ones to replace the endlink (grommets) bushings.
I'll let you know how they are but I am also replacing the control arms so if this car handles better I won't know which thing helped the most since all the stuff is going on at the same time.
Old Jul 26, 2006 | 01:46 PM
ThurzNite's Avatar
They work great, and good price.
Jae
Old Jul 27, 2006 | 03:24 PM
Keep me posted.
Old Jul 27, 2006 | 05:40 PM
RedfoxXx's Avatar
i also like them, they last better then stock
Old Jul 28, 2006 | 08:03 AM
Dubbya's Avatar
VK56 Inside
I used them and tossed them in the trash shortly after. The bushings tore in half about 4 months after I installed them. After that I replaced them with OEM ones. No problems since.
Original thread:
http://forums.maxima.org/showthread....rgy+suspension
Old Jul 28, 2006 | 01:09 PM
crazy97's Avatar
Original thread:
Crap, well at least they will be easy to fix if they fail.
Old Aug 3, 2006 | 06:29 PM
crazy97's Avatar
Originally Posted by Wheelie King
Keep me posted.
Everything is installed (Control arms/ball joints, energy suspension swaybar link bushings), except for the swaybar to frame bushings from ebay...they haven't arrived in the mail yet.
Old Aug 3, 2006 | 08:01 PM
f550maranello2's Avatar
Original thread:
im gonna agree with that... i just go some tie rod ends from ebay... 4 months ago.. both of the boots are already all cracked.... get oem stuff u pay more but at least ur guarenteed 10 years out of it...
Old Aug 11, 2006 | 07:22 AM
crazy97's Avatar
I've had my ES swaybar to frame bushings on for a few days now and they seem to help cornering a little but it seems like the rear end is not nearly as solid as the front.
I would rate my suspension like this:
Bone stock without front strut bar 4 out of 10
With FSTB 5 out of 10
With new control arms and ES swaybar link bushings/oem swaybar bushings 7 out of 10
With ES swaybar bushings 8 out of 10
Old Aug 11, 2006 | 05:26 PM
97SEdriver's Avatar
this place is dead
bump this thread if they get shedded, pm me if you need help finding it.
Old Aug 12, 2006 | 04:18 AM
dgeesaman's Avatar
Maintenance Monster
I have all of that and my handling is still 3 out of ten. Blown struts.
Anyway, my point is that ES bushings are much better than worn out stock bushings. But they're hardly any different from good stock bushings.There's no need to get a chubby about them. "Upgrades" don't make the difference, replacing what's bad makes the difference.
Old Aug 12, 2006 | 04:51 AM
Albert's Avatar
I had the ES front sway bar bushings replaced twice and gave up.
Like someone had mentioned earlier, they tore in less than a year.
I was certain that I had installed them correctly with the split facing
the same way as OEM. I went back to OEM. I do have the endlink
bushings and they are fine.
Old Aug 12, 2006 | 12:23 PM
crazy97's Avatar
Yeah, I don't think those bushings even could have a huge effect but the ones I replaced were probobly the oem ones that were on the car since it was new. Maybe I should give the ES bushings a .5 improvement in my rating instead.
AcuraLegend
Oct 17, 2016 08:47 PM
Starrider
Dec 18, 2015 04:43 AM
AcuraLegend
Sep 22, 2015 04:22 PM
jfl330
Sep 4, 2015 01:44 PM
A32goldylocks
Sep 2, 2015 06:39 AM
